Farmtrac 360DTC Won’t Shut Off
   / Farmtrac 360DTC Won’t Shut Off #1
Opa4311
Farmtrac 370 DTC
Howdy
Put new starter on. Had wires reversed and it wouldn’t shut off until we stalled it. Fixed wires.
Then it would turn over fine and run but wouldn’t shut off so I took the fuel solenoid out and grounded it. While turning the ignition key to see if solenoid worked, it cranked with solenoid out and had to stall it again.
Is this:
Fuel shutoff solenoid?
Bad starter relay?
Bad ignition switch? (For several attempts, there was only slight click sound at starter. Nothing at fuel shutoff. Then today it cranked easily but would not shut down.)
Any ideas ? We will try anything.
Don’t think so. Runs smoothly. No smoke at all. I suspect ignition switch but all five wires are soldered on. Asking for ideas first. Thanks
   / Farmtrac 360DTC Won’t Shut Off #4
Might have a bad ground, check the ground wire to the frame.
   / Farmtrac 360DTC Won’t Shut Off #5
Howdy
Is this:
Bad starter relay?
bout have to have it wired up wrong
   / Farmtrac 360DTC Won’t Shut Off #6
Reminds me of the time the parts house sold me the wrong starter solenoid for my old F250. Once it started cranking, it didn’t want to stop.
2021 Toyota Corolla LE Sedan (A55758)
2021 Toyota...
2004 Ford F-250 4x4 Service Truck with Liftgate (A55788)
2004 Ford F-250...
2023 VOLVO VNL760 SLEEPER TRUCK (A54313)
2023 VOLVO VNL760...
TAILGATE (A54756)
TAILGATE (A54756)
2014 KENWORTH T680 SINGLE SLEEPER ROAD TRACTOR (A54756)
2014 KENWORTH T680...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
