Farmtrac 360DTC Won’t Shut Off
   / Farmtrac 360DTC Won’t Shut Off #1
Opa4311
Farmtrac 370 DTC
Howdy
Put new starter on. Had wires reversed and it wouldn’t shut off until we stalled it. Fixed wires.
Then it would turn over fine and run but wouldn’t shut off so I took the fuel solenoid out and grounded it. While turning the ignition key to see if solenoid worked, it cranked with solenoid out and had to stall it again.
Is this:
Fuel shutoff solenoid?
Bad starter relay?
Bad ignition switch? (For several attempts, there was only slight click sound at starter. Nothing at fuel shutoff. Then today it cranked easily but would not shut down.)
Any ideas ? We will try anything.
Don’t think so. Runs smoothly. No smoke at all. I suspect ignition switch but all five wires are soldered on. Asking for ideas first. Thanks
   / Farmtrac 360DTC Won’t Shut Off #4
Might have a bad ground, check the ground wire to the frame.
   / Farmtrac 360DTC Won’t Shut Off #5
Howdy
Is this:
Bad starter relay?
bout have to have it wired up wrong
   / Farmtrac 360DTC Won’t Shut Off #6
Reminds me of the time the parts house sold me the wrong starter solenoid for my old F250. Once it started cranking, it didn’t want to stop.
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2019 Freightliner M2 106 AWD Altec AM55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2005 INTERNATIONAL 4300 SBA 4X2 FLATBED TRUCK (A58375)
2005 INTERNATIONAL...
LOT: Assorted Liebherr Filters (A59076)
LOT: Assorted...
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
