farmer
/ farmer #1
enviroworks
livingston, texas
JD 700 J
my 2006 JD 700 J slowed to a crawl in high speed. I killed the engine and tried to restart transmission when tractor went to an idle and does not respond to engine speed control or forward and reverse.
What happened??????
/ farmer #2
When was the last fuel filter changed?
/ farmer #3
What happened??????
Sorry but that's why you by case ih made in USA not japan
/ farmer
fuel filter changed recently, not a fuel issue. Intermittent issue , After restarting several times dozer would respond to engine speed control but would not respond to forward and reverse. It is all electronicly controlled. it must be some sensor or elect control. I just don't know how to find out what
/ farmer #6
If an engine is a Common Rail one, for me it looks like loosen engine speed sensor connection or accelerator pedal potentiometer fails.
But the best idea would be to diagnose that failure with a special device available at the dealer.
/ farmer #7
Ah, one more important thing: check the EGR valve FIRST, if fitted (I think it must be). Could be broken inside.
2013 Ford Escape AWD SUV (A61569)
2013 Ford Escape...
Andersen Fifth Wheel Hitch (A61166)
Andersen Fifth...
2019 Caterpillar D5K2 LGP Crawler Tractor Dozer (A61567)
2019 Caterpillar...
02GER CHICKET HOUSER 240' (A62131)
02GER CHICKET...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
6066 (A61165)
6066 (A61165)
