Farmall Cub questions
/ Farmall Cub questions
/ Farmall Cub questions #4
Google is or can be your best friend. I found my original link via google. Just google IHC J4 magneto test and go from there.
/ Farmall Cub questions #5
Have a friend hold the coil wire while you crank it ����
/ Farmall Cub questions #7
condensers are capacitors. test them with an ohm meter.
short the pigtail to the body to discharge it.
set a meter to Rx1
put leads on the pigtail and body. On an analog meter, the needle will swing from 0 ohms to infinite. On a digital it will go from a low reading, probably auto range a bit, then indicate infinite.
Condensers that read infinite all the time are open, ones that read 0/low and never increase are shorted.
