Farmall A
   / Farmall A #12
I think I found that the "J" means 1940. Does that sound right to anone.
   / Farmall A #13
I posted this sometime back. Check on the engine block as described below. IF it is the original engine, you should find your tractor's serial number.
Originally Posted by DJ54
I stand corrected of a second serial number location... Don't know what I was thinking...
Look on the right front corner of the block, just above the mag, or distributor drive. There is a flat boss just below the head with the serial number stamped there.
You may need to scrape the paint off to see it, if you haven't already found it.
   / Farmall A #14
hopefully it is the original block
   / Farmall A #15
I'm almost positive it is because like I said it was my grandfather's and it was his baby. I did find that flat spot on the block but I could see any numbers at all.
   / Farmall A #16
I'm almost positive it is because like I said it was my grandfather's and it was his baby. I did find that flat spot on the block but I couldn't see any numbers at all.
   / Farmall A #17
   / Farmall A #18
Found the block # FAA 18953
Looks like it is a 1940. Can I get another serial tag using that number?
   / Farmall A #19
Hope you taking before and after pic of this tractor! :)
   / Farmall A #20
Will be posting before pictures soon. Where is the best place to get parts for this tractor?
3-4 CU/YRD PULL TYPE DIRT CARRY PAN (A58374)
3-4 CU/YRD PULL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
SKID STEER ATTACHMENT MAINTAINER BLADE (A58216)
SKID STEER...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
