Farmall A
   / Farmall A #12
I think I found that the "J" means 1940. Does that sound right to anone.
   / Farmall A #13
I posted this sometime back. Check on the engine block as described below. IF it is the original engine, you should find your tractor's serial number.
Originally Posted by DJ54
I stand corrected of a second serial number location... Don't know what I was thinking...
Look on the right front corner of the block, just above the mag, or distributor drive. There is a flat boss just below the head with the serial number stamped there.
You may need to scrape the paint off to see it, if you haven't already found it.
   / Farmall A #14
hopefully it is the original block
   / Farmall A #15
I'm almost positive it is because like I said it was my grandfather's and it was his baby. I did find that flat spot on the block but I could see any numbers at all.
   / Farmall A #16
I'm almost positive it is because like I said it was my grandfather's and it was his baby. I did find that flat spot on the block but I couldn't see any numbers at all.
   / Farmall A #17
   / Farmall A #18
Found the block # FAA 18953
Looks like it is a 1940. Can I get another serial tag using that number?
   / Farmall A #19
Hope you taking before and after pic of this tractor! :)
   / Farmall A #20
Will be posting before pictures soon. Where is the best place to get parts for this tractor?
Massey Ferguson 4608 (A53317)
Massey Ferguson...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2020 DRAGON ESP...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
6" X 1" X 10' FLAT IRON 4-STICKS (A58374)
6" X 1" X 10' FLAT...
