Farm pro clutch installation question
/ Farm pro clutch installation question #1
frwlf2
king & queen, Va
farm pro 2425
I have a Farmpro 2425 that the clutch went out. I have split the tractor and removed clutch pack. I purchased a new clutch assembly from Affordable tractor. I have bolted the assembly back on to the tractor. I am trying to figure out the next step. I read post about stack height. Trying to to figure it i need to set the stack height or do I bolt the tractor back together and and worry about the distance of the fingers to the TOB. If I put it back together, do you adjust the fingers to the TOB or visa versa. I'm trying to find out the correct procedures so I can get my tractor up and running again. Any help would be much appreciated.
/ Farm pro clutch installation question #2
/ Farm pro clutch installation question #3
You cannot do the main clutch adjustments until the tractor is back together, you can do the PTO setting, but not the main disc, make sure to use a clutch alignment tool ,I have seen a lot of damaged discs from people not using one
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
So how do you go about adjusting the PTO before it’s assembled?
