Farm Pro 2425 steering help please
   / Farm Pro 2425 steering help please #1
ymurf
I seen a thread on here the other day about when turning the steering the steering wheel keeps turning even though the tires are as far as they can go.Now my farm pro 2425 is doing that and cant find the thread again.Does anyone here know what is the problem that causes that.It steers fine but the steering wheel will keep turning? It is a 2003 model.Any help would be appreciated.
   / Farm Pro 2425 steering help please #2
Blown piston seal in the steering cylinder? Blown/damaged vane/seal in the steering valve?
Got a mechanics stethoscope? If it is a blown piston seal in the cylinder, you should be able to hear the fluid flowing around the piston by listening to the cylinder case as someone turns the wheel with the steering hard over...
   / Farm Pro 2425 steering help please #3
I'm sure you probably did this already, but did you check the fluid level in the reservoir? Does your Farm Pro have a separate reservoir for the steering? How about checking the filter screen to see if it's plugged up or not?
I know some guys have gone to a thicker fluid for the steering pump too. You might check those things after you check what Ron told you.
   / Farm Pro 2425 steering help please #4
99 percent chance its the seal on the steering cylinder. I'll bet Tommy at affordable has a kit. not too bad a job to do. Not really necessary unless it gets hard to keep the tractor going straight.
   / Farm Pro 2425 steering help please #5
I vote for the steering cylinder.
Ronald
Ranch Hand Supply
Thats kinda what i was wondering,If its ok to run like that.Cause it steers fine,just the wheel will keep turning.So it shouldn't hurt anything?
   / Farm Pro 2425 steering help please #7
The oil just seeps past the seal on the piston and leaks out the return side. when it gets bad enough, it will get difficult to hold a straight line. I'd get the parts and then when you have nothing better to do or if and when it gets bad enough, you could rebuild the cylinder.
Could someone point me in the right direction to get this part and is there any info on how to fix this?
   / Farm Pro 2425 steering help please #9
Whereas the cylinder diagnosis is quite common - and very likely correct - it would also pay to look for leakage beneath the hydrostatic controller. That's the device at the bottom of the steering column where four hoses connect. Jinma calls it the "steering machine ". One of my tractors - I think it was a Jinma - had a leak there that affected the steering. The bolts holding the bottom plate got loose enough for fluid to be forced out when I turned the steering wheel. Working clearance was tight, but I was able to tighten them all down with a box wrench. End of problem.
//greg//
   / Farm Pro 2425 steering help please #10
Our 2420 had that happen to it. The seal in the cylinder is pretty much junk chinese parts. You'll get replacements that are of better and longer lasting quality. I replaced mine and the steering's been fine since. It took about 1/2 to do. I'd rate it as a easy fix.
Steve
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
UNUSED GOLD MOUNTAIN M202010 20'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2021 Vermeer Wood Chipper (A51573)
2021 Vermeer Wood...
