Farm Pro 2425 Engine Knock
/ Farm Pro 2425 Engine Knock
A little update. I have been tied up the last few weeks and not able to work on the tractor until this weekend.
I don't know if it was mentioned in my earlier posts, but all 3 injectors were replaced with new injectors when the head gasket was replaced, along with new glow plugs.
I rechecked the timing and believe it was set correctly. Started the tractor to move some dirt and rocks and it starts knocking really hard after a few minutes of working. It will come on all of a sudden and the tractor will slowly shut down without smoke or any other indicators. Temperature is heating up beyond the 60C once it was working. I'd say it was right around 100C when each time it shuts down. I can restart it immediately and the knocking seems to be gone, but comes back after a few minutes or once I start to load up the tractor. It does seem to start pushing a lot of smoke out of the crankcase breather as it begins to die.
I did go and purchase a diesel compression tester and found all of the cylinders easily build up to 375psi in about 3 cycles. All reach similar pressures and do not seem unbalanced. I did find that when I pulled out the 3 brand new glow plugs, 2 of the 3 tips seemed to be "melted" off. They have a hole in 1 side of the tip, and the other side is what looks to be "melted" open. I haveused the glow plugs a few times to start the tractor but otherwise they are unused. I found this interesting, maybe they were wired to be on all the time? I replaced them with my old glow plugs for the time being.
Also noticed it looks like the engine oil is filling with diesel fuel. I thought the oil looked diluted so I have changed the oil. Within about 15 minutes of use the new oil looks to be diluted and "watery" as well. I could not determine if this was diesel fuel, hydraulic oil or coolant, however I believe it is diesel fuel since the hydraulic reservoir is staying at the max fill level and the oil is not turning brown or milky.
It did seam like if the engine began to knock that I could press the primer on the fuel pump and it would be soft. Pumping using the hand primer seemed to make the knocking go away sometimes but was not always conclusive. I pulled the fuel line from the tank to the pump and verified it was not constricted. Pulled off the sediment bowl to look for restrictions and did not see anything alarming other than torn filter screens. I did end up placing a new sediment bowl on from tractor supply when I reassembled.
I'm at a loss again. I pulled the valve cover to verify there are no sticking valves while it is running. Can't come up with a good reason for why there is fuel in the oil while there is still good compression, or why this knocking is still happening.
Looking for any more advise for things to check after.
Thanks again - Eric
/ Farm Pro 2425 Engine Knock #22
Do you have any fuel driven preheater in the intake manifold? If not have you tried to loosen one injector line at the time to see if all cylinders react in the same way? Except the preheater tis not many ways for diesel to enter the engine, dead cylinder, leaking injection pump or feeding pump.
/ Farm Pro 2425 Engine Knock #23
The knocking almost sounds like AIR in the fuel system.??
U say once it starts to knock, it slowly dies out..
& u said, working the HP will make the sound dissipate..
It sure sounds like air to me..
Pressurizing the fuel tank w/ air, about 4 psi, will usually show a loose fitting or pin hole pretty fast..
U could lightly dust the fittings w/ baby powder & any leak will show itself..
Good luck..
/ Farm Pro 2425 Engine Knock #24
BTW> if u google>> "Farm Pro 2425 injectION pump"
Theres MANY threads about this mdl machine..
Hey thepumpguysc, I completely agree it sounds like air in the injection lines. I'll make another attempt to check all the connections for air. I have parked the tractor for the time being.
Any reason why the engine oil sump would be filling with diesel fuel? I was starting to think the injectors may be dripping or something else? I did replace all 3 injectors when I started into trying to fix this issue.
I am also beginning to suspect the injection pump as well. The pump was purchased as "new" open box from a seller on ebay. When I received it the condition looked new, but the fuel rack was stuck, as well as one of the injector/plunger springs behind the rack. I ended up freeing the rack and the plunger before getting the tractor to run, but now I am second guessing the quality of the injection pump.
IF the pump was not operating correctly could this potential cause the injectors to overfuel? If the plunger sticks in the "up" position would that keep the fuel pressure in the injection lines high enough to drip/leak fuel into the cylinder?
I am convinced there is fuel leaking into the oil sump to fill over time and becoming diluted with diesel. I have changed the oil 2 times since the first time I noticed this and have found the oil over filled and diluted each time. In both cases the tractor had been run for no longer than an hour.
Thanks,
Eric
/ Farm Pro 2425 Engine Knock #26
I would suspect the lift pump, if it has 1..
THAT would account for ALL your problems..
A leaking Lp would flow a large amount of fuel in the cc AND..
...with it leaking, wouldn't supply the correct amount of fuel to the inj. pump..{air}
/ Farm Pro 2425 Engine Knock #27
I had that thought too but on my Y385 the lift pump attached to the injection pump and when it leaked it filled the IP case with diesel to the point it overflowed the breather. Unless the lift pump is connected to the engine block, I don't see how it could put diesel into the oil in the engine crankcase unless the seal between the IP and engine at the drive end was also bad.
If the leaking injector has indeed damaged the cylinder wall as bad as it looks, that is the most likely place for diesel to get into the crankcase but that would mean that the injector is still leaking excess fuel.
On my tractor the lift pump was run by a push rod powered by a cam in the IP. That rod was sealed by an o-ring and it proved difficult to keep a working seal. I removed the lift pump, made a cover plate and gasket to seal off the r hole in the IP. I then mounted an electric lift pump near the fuel tank and all has been well since.
Just wanted to update everyone on the tractor. I ended up ordering a rebuild kit and started to tear it down today. Found that 2 of 3 of the pistons were damaged and cracked near the piston rings. All of the piston rings are intact and look to be in acceptable condition. See the attached pictures for reference.
Originally I had suspected a spun bearing, but all of the crank bearings look to be in excellent condition.
Just wanted to update the thread in case anyone else found a similar issue and wanted closure.
Thanks,
Eric
/ Farm Pro 2425 Engine Knock #29
How was your ETHER usage.?? Were u the only one operating the machine.??
I ask because someone else might have used it..??
/ Farm Pro 2425 Engine Knock #30
I suspect excessive ether (starting fluid) usage too. The flame front is passing by the first and second ring. Also, the ring indexing could have been bad. I couldn't quite see the liners well enough to detect if they are scored or not, or how big the ridge is. At any rate, the liner condition will predicate if you can reuse them, and the rings.
Alright, back for some more help.
Got the engine back together after tearing it down. It has new bearings, pistons, liners, rings, gaskets.... the works.
Got it together and started today. Took a long time to get it to start, but it started and I moved it out of the garage. It is still smoking (white smoke) pretty good all the time. I dont know if they smoke is a problem, but I imaging it shouldn't be smoking much at idle, and when you throttle it up it does bellow out more smoke (brownish white). After letting it idle for a while, I brought up the RPMs for a little while (15 sec?) and when I let off it started knocking really bad. Knocking sounds exactly like what caused me to start down this path. At the same time as the knocking started, the valve cover started smoking from the hold down nut holes. It was also smoking white smoke out of the breather on the bottom of the tractor. When I shut it down I pulled the oil fill cover and noticed a lot of lingering white smoke. I put my finger in the hole for a few seconds and it comes out wet (drips of water/condensation?). This seems wrong to me as well. **** it...
I'm at a loss again? Could this be a cracked head? Hopefully not a cracked block. I attached some images of the rebuild with all new parts, and also an image of the white smoke at idle.
Maybe you guys could point me in a direction on what would cause the white smoke in the crankcase?
IMG_20200307_092818.jpgIMG_20200307_092820.jpgIMG_20200307_100512.jpgMVIMG_20200307_161804.jpg
/ Farm Pro 2425 Engine Knock #32
your work looks clean and careful. As for the white smoke, I would expect a rebuilt engine to smoke a little until it is broke in again.
The real question is if you are getting coolant into the combustion chamber or the oil pan. I think there are test kits available to do some sample testing of the oil and coolant to see if they are mixing.
The knock is perplexing to say the least. I don't think a coolant leak would contribute to a knock unless it was a massive leak.
Sorry I don't have more to offer than suggest magna-flux of the head to check for cracks. Although at this point I don't really think that would lead to the knocking condition.
Hopefully someone with more experience will chime in.
/ Farm Pro 2425 Engine Knock #33
Are it running on al cylinders? Are all exhaust ports warm? Did you check the injectors?
/ Farm Pro 2425 Engine Knock #34
White smoke that lingers in the air is unburned fuel. White smoke that dissipates rather quickly is moisture, and can be caused by just cold exhaust (goes away after a short time) or coolant in the combustion gasses. This is all dependent on ambient temperature and humidity conditions too. In your case I suspect a dribbling injector. Next time you hear knocking, loosen the fuel line nuts at the injectors one at a time and notice if the knocking sound subsides or goes away. The brownish exhaust under acceleration suggests over-fueling, either from timing (unlikely here), or clogged air filter. Worth a check.
I'll second Piper184's assessment of your work - nice clean job.
Thanks for the pointers guys! This actually may have found something.
I tried running the tractor and loosening the injectors. Injectors 1 and 3 caused the engine to bog down pretty good, but loosening injector 2 didn't seem to have any effect on the engine. I also noticed when I loosened 1 and 3, the stream of fuel seemed to pulse out as a stream, whereas on injector 2 the fuel seemed to "foam" out. See the picture below - not sure if it is obvious but there are white foam bubble on the fuel line just behind the nut. Don't mind the water droplets everywhere else, it is starting to rain at the moment. Also wanted to note that the smoke from the exhaust did not go away as I loosened the injectors.
I have some spare injectors I could swap in. The current injectors are all new that I bought when I started diagnosing the issue. So I can try swapping one of the old ones in, or swapping this injector to another cylinder and see if the problem follows it.
Also wanted to note that while I just ran outside and started it to test the injectors, it was not knocking at all (it seems it has to get warm before it starts knocking. But there is a "ticking" noise. That ticking does disappear when I loosen the #2 injector.
Does this sound like I just have an injector issue?
Thanks again! Really appreciate the help.
Eric
/ Farm Pro 2425 Engine Knock #36
The foaming from #2 injector suggests compression blow-back because the pintle valve in the injector isn't seating (also why it would be dribbling ((and ticking)) fuel when it shouldn't). Hopefully the knocking is the accumulation of fuel in the combustion chamber trying to hydraulic lock (this is as serious as a bad rod bearing). Change out that #2 injector and see what you have.
Alright, had some time this morning to look into the tractor again. I pulled the #2 injector and swapped it with another one. No effect at all.
I decided to remove the service cover on the fuel pump to try and see if anything was sticking or causing the injector to receive less fuel than the other injectors? I can't say that anything was gummed up, but I did clean everything out with carb cleaner and WD40. Rinsed with new oil and started it back up. The number 2 injector now causes the motor to stumble when I loosen the fuel line. But now the engine is knocking really hard again. This knock was not occurring since the last post I made. and seems to be a new issue?
I tried cracking each injector to see if one seemed to be the cause of the issue, and now #3 makes the knocking sound completely go away. I recorded some videos of this effect as a reference.
FarmPro 2425 Engine Knock 4
I assume now that the knocking sound is a "fuel knock" based on the ability to remove it by cutting fuel to an injector.
I also noticed that if I increase the RPM the knock continues while the engine is under load, but as soon as you let off the throttle the knock sounds goes away until the engine speed has stabilized. Just a reference point, trying to gather some diagnostic data.
Is there a possibility the fuel injection pump is the problem? Could the injectors be out of sync?
Thanks again as always,
Eric
/ Farm Pro 2425 Engine Knock #38
Just some random thoughts here:
If you swap the #1 injector with the #3 injector and the problem follows the injector that will be easy to fix. If the problem stays with #3 then it is either the pump or a problem in that cylinder.
I can see how excess fuel could cause more combustion in one chamber, but if it goes too rich it wont fire. I would think that the smoking might be related somehow. If you are getting enough fuel overload to cause hydraulic lock it would definitely be washing down the cylinder wall and that would be really bad and should be obvious if you pull the head.
Finally could there be a restriction in the intake manifold that would cause the #3 cylinder to run richer than the others? For that matter could the valve timing and clearance be off for #3? Maybe something slipped when you put it back together. A second look might be a good idea.
One question I have is could that piston have been installed wrong? I don't know if they have to be installed a certain direction.
If #3 is knocking when firing but not when coasting what physical parts could do that? Rod and crank bearings, piston and wrist pin. Could the piston be slapping the cylinder some how?
Hey Piper,
All good points, I have tried moving the problem injector around and it seems like the problem does not follow the injector. I believe the reason the knock has changed locations is due to my meddling with the injector pump fuel rack.
A little more backstory - back to where this all started in post #1. I bought this tractor "running" but with significant issues. In the original diagnostic we determined there was an issue with the fuel delivery being inconsistent, and when I pulled with injector pump timing gear I found the woodruff key on the old pump was sheered off and the bearing on the shaft worn out. I bought a "new" pump and pulled the old one. I still have the old one and have been going through it to learn a little more about how the pumps work and how to tune them.
So fast forward to the new pump. Arrives with all the ports covered, looks new. Try to pull the fuel shutoff and it is locked tight. Before I install it on the tractor, I pull the service cover to see if the fuel rack is stuck and it is. Golden gummy film on the entire gallery. I sprayed some WD40 in the whole compartment and used a screwdriver to pry the rack back and forth to free it up. As a reference, I have my old pump available and for comparison, it's fuel rack is smooth as silk. In the process of doing this the screw down clamps on the rod slip in position. See the image below for a reference of the screws I am talking about - this in on my old pump that I have laying around now.
I realized that this was probably an issue, and loosend all of the clamps. Slid them all to the left side of the rack until each "bound" and then re tightened. In retrospect, I think this was the point where I messed up.
Cleaning the gallery again today also caused one of the clamps to slip - so I moved it and re-tightened. After restarting the tractor is has the loud knock on the #3 cylinder. Typing this all out makes me believe I have messed up the injection pump calibration/setting and that is the source of my issue.
Can anyone confirm this is my issue? And if so, is this something I can correct or do I need to replace the pump again or have this one serviced?
/ Farm Pro 2425 Engine Knock #40
Moving the segments IS DEF. where u messed up.!!
THOSE ARE the individual fuel adjustments for each cylinder..
I have set them ON the tractor before..{Ford}
IDK if "YOU" should do it while the pump while its running..??
Here what I suggest>> remove the side cover, pull the stop to find out which DIRECTION is STOP..
Then, with the engine NOT RUNNING, move # 3 segment SLIGHTLY to the stop direction..
U have HEAVY BLACK smoke, right ?? that means its over fueling.. so u wanna cut the fuel back.. so u move it in the cut-off direction..
AND TIGHTEN..
THAT adjustment is very sensitive.. so go slow.. restart the engine & see what u have done..
Good luck..
TIRE RACK WITH TIRES (A68842)
TIRE RACK WITH...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2007 MACK VISION (A67714)
2007 MACK VISION...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
