Farm Pro 2420
   / Farm Pro 2420 #1
luck3
farm pro 2420
Hi my name is chuck and i just got me a used farm pro 2420. I don't know much abouth tractors since this is my first one. My question would be on how to hook up the hydraulic lines from a koyker 160 on to the tractor. I got the loader mounted but now are stuck I dont know where to connect the pressure and the return line.
   / Farm Pro 2420 #3
Mine, a 204 with a 140 Koyker.
There are (or should be) two lines connected together with a quick connect on the tractor, right side, disconnect these and connect them to your loader. DO NOT run the tractor without these lines either being connected back together--or-- to the loader, if you do you'll deadhead the pump, an expensive proposition.
Post back and tell us how you made out or any probs and I'll post a pic of mine, oh and welcome :) .....Mike
**EDIT**
I just thought, have you any idea if the fluids have been changed, hydro, trans, oil, coolant, diffs? It's a prerequisite of owing a Chinese tractor that the fluids be changed immediately after purchase, the ones they use from the factory leave a lot to be desired.
   / Farm Pro 2420 #4
Hi Chuck!
Asian Tractor Parts has a great selection of Chinese built tractor parts that are factory direct! check out www.asiantractorparts.us for a list of parts. They have great customer service and helpful with troubleshooting! Definitely recommend
RHINO X1808 LOT NUMBER 43 (A53084)
RHINO X1808 LOT...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
9202 (A50322)
9202 (A50322)
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
