Factory engine oil filter like it was welded on
   / Factory engine oil filter like it was welded on #31
I too took the screwdriver to a oil filter. It did the same thing. Ripped the oil filter top off completely. A giant mess of oil everywhere on me and the cardboard i was working on in my parents driveway. I then "broke" the neighbors oil filter removal tool (a longer version of my cheapo type of harbor freight tool but at the time made in Taiwan as they were the USA's junk maker). AFter all that I ended up with a chisel banging on it with a 2 lb sledge at an angle. Slowly it relented but again after hours of just getting the filter off I finished in the dark at 10pm so i could go to work the next day. But, I got lucky compared to another guy in my office. He had a nearly new Monza at the time. He changed his oil and ended up with a double oil gasket (one stayed on and new one on new filter) and it worked loose on him on the highway. Lost all his oil, blew the engine and he missed work for a few days. I consider my problems minor still compared to that.
Steve
   / Factory engine oil filter like it was welded on #32
This...The more you pull the more it digs in. Never had it fail to remove extremely tight filters
   / Factory engine oil filter like it was welded on #33
I have a similar one with out the grippers......
It is worthless as tlts on a boar
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
