F3080 wheels don't turn with steering wheel....sometimes. Anyone else???
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #11
Just wonder are you running it wide open?
Also I have seen this problem before it was the priority valve on the hydraulic pump it is giving the hydro all the oil 1st which it is suppose to do but some times if you are not running wide open you are not moving enough oil to get the steer to work.
15 Kubotas and rarely have I ran any of them wide open but will try it when I next mow to see if it makes a difference. Grass is so high with all the rain that I'll need to run it wide open this time anyway.
Thanks for a possible solution.
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #13
That was one question I did not think to ask.
John there should be a F3680 at Barlows soon for you to admire/drool over, just not with the 102 inch deck. ( I did ask Steve to see if he could get one to display ) You could trade in that side discharge deck F3080 on it. I ordered the 60 inch rear discharge deck, traded in the ZD331.
I drove up 27 which I used frequently in the early 70's to visit grandparents, could not believe the growth in Burnside and Somerset. The traffic light at 27 and 80 was the major intersection back then.
What have you done? Not sure from your post. Have you bought a 2nd F3680 and traded your Z toward it? Hal Rogers is from Somerset so we have many road improvements and I appreciate them, will keep voting for him.:laughing:
Mowed today. Grass really high. Lifted front deck, replaced broken piece on one of the blades that was bad from factory and Gary at Barlows gave me a new one under warranty. Raised my back wheels a smidge, need another smidge after mowing.
Revved it all the way, still some times doesn't turn tires with steering wheel. Did it first time as I was pulling out of tractor building. I believe it may just be doing it when turning steering wheel to the right. A few times I looked at tires and they weren't moving while I was spinning the steering wheel. Turn wheel left then right and works fine. No air bubbles on the dip stick when it was not turning tires.
Will stop at Barlows tomorrow and report todays mowing/failure to turn right at all times with full out throttle and no air bubbles on trans dip stick.
I'll also see what you done on your trade.
I was on flat and hillside when it don't work.
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #15
Yes it is your doing, if you could have two F series I could too. Traded in ZD331 60 inch side discharge for another F 3680 with 60 inch rear discharge.
Drove up Monday after work to submit paperwork and to meet Steve. Was looking for the old site of West Somerset Wrecking that an uncle owned part of could not see any remainder. I was told the dirt track on North 27 was also gone.
While the ZD mowed well on ground it was suited for, I cut a lot of other areas.
The 60 inch deck is for areas I have that are too tight for the 72 inch deck.
:thumbsup: :thumbsup: Good for you. I keep telling my wife that if one is good two is better when I find something I like or a bargain.:D That's why I have all the extra buildings, to keep those extras in that I eventually give away.:)
Did you bring the Z and leave it or will there be the swap when your new one arrives? How many hours on the Z? Is Barlows delivering your F or are you coming back to get it?
I've been here in Somerset since 1974 and the changes are never ending. Guess that's the way it is in many mid size towns. Just West of Barlows is a Mobile Home park called Raceway. It finally struck me one day that Raceway used to be the Drag Strip that I came to in 1964 or 1965.
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #17
If it arrives soon will swap down here. Have to replace the power steering on my F350 PSD before I can haul anything up there. Need to clear the lower field on my farm property.
The ZD has 410 hours on it and has been parked until handed over. Will check with Barlows on delivery date if everything comes in. Otherwise I will haul the ZD up there, they cannot get anything for it sitting down here. My TN farm tax exemption would probably not work if I picked the #2 F3680 up there.
Thought about a F3080 with the 60 inch deck but decided having twin 3680s was better.
Have been reading about a front mounted flail mower (Verismo ?) that fits, the list price was over 7K however. Or if I hit the powerball I could try the 102 inch deck.
Hope others see the benefits of the F series. I think Kubota should have a demo model at the larger dealers for better exposure.
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #18
I could not find a F series at any dealers in my area and went with a Ventrac 4500
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #19
In another thread I mentioned the only one I saw on a dealers lot was my first one back in 2006. I think they had sold some to different government agencies. Here the city is running front mount Grasshoppers cutting the road frontage and center strips of the divided highways.
Have read about the Ventrac but same problem, no close dealers plus I have tractors to do the heavy cutting/ lifting. If I cannot cut a slope with a F series I do not want to be on it.
   / F3080 wheels don't turn with steering wheel....sometimes. Anyone else??? #20
Well for me a Ventrac dealer are not too hard to find seeing their made less than 25 miles from me.
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
Unused 2025 CFG MX50R Mini Excavator (A49461)
Unused 2025 CFG...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
71059 (A49346)
71059 (A49346)
