F3060 2 Micron Racor installation
   / F3060 2 Micron Racor installation
......snip.......
What amazes me is the negative reviews. People install them on gas powered engines and then the clear bottom bowl falls apart. For diesel only folks, not gasoline but then I guess people aren't too bright.
Well misapplications happen sometimes when people do not pay attention and just assume something!
Many automatically / immediately blame the equipment.
RACOR certainly makes good filtration for marine gasoline applications which should work fine for any gasoline engine:
   / F3060 2 Micron Racor installation #12
Obviously, the bowl is made from something that gasoline won't degrade unlike the diesel only ones. People don't bother reading the 'fine print' today and then whine when something fails.
Never had issue one with any gas powered motor in anything I have. The inline pleated filters seem to do a fine job in that respect. Diesel is another story, especially with equipment you fill the tank from the top or let the fuel sit in a half empty tank for a long period of time.
   / F3060 2 Micron Racor installation #13
Arto... Did you have to install an extra 12 volt fuel pump to insure adequate fuel flow? Reason I ask is, I now have the IFJF base with a 2 micron Racor 2 micron spin on fuel filter on it that I'll mount where yours is mounted at. If you did install a second fuel pump, where did you put it and what brand and delivery pressure? OEM Kubota electric pumps are stupid expensive even with my employee discount.
I would check Facet brand small 12V fuel pumps for replacement if new pump was ever needed.
The original fuel pump has been perfectly adequate, and in F3060 it's easy to check the excessive fuel flow returning back to the fuel tank, but I have only checked it with the engine idling.
I just did over two hours of mowing yesterday and it worked fine.
PS.
It's easy to switch to Racor 12T (10 Micron) if pump capacity ever became a problem.
   / F3060 2 Micron Racor installation #15
I have a few of the 10 micron filters on the shelf as I run them on my pair of Kubota M9's. Thanks for the information. Was going to buy a second electric fuel pump but I'll adopt a wait and see attitude at this point.
   / F3060 2 Micron Racor installation #16
I like these spin on filters you guys have plumbed in (y)
I run a 10micron 3qt spin on filter with hydroZorb membrane for moisture on my 550gal tank.
Both mowers & 3 tractors gets filled from this tank weekly.
This setup was EXPENSIVE but I hadn’t replaced a fuel filter on any 5 units in 4yrs.
   / F3060 2 Micron Racor installation #17
According to what I've read, the IFJF 10 micron filters filter as good or better than the more expensive Racor filters and actually have more filtering material (pleats) than the Racor's do at a substantially lower price. I'd say if you can overlook the fact they are Chinese, they seem to be a better (less expensive) alternative.
Been using my new / used 2820 side discharge deck and it's a mowing fool. Even mowed around the perimeters of my hay fields with it. Saves me getting too close with my disc mower and snagging a fence posI always mow in low range so the deck don't bounce around at all. Mowing, at least in my view should be a relaxed thing, not a hurry up thing. It will throw clippings about 10-15 feet if I want to but when I mow the edges of the hayfields, I point the discharge towards the fence line.
   / F3060 2 Micron Racor installation #18
This setup was EXPENSIVE but I hadn’t replaced a fuel filter on any 5 units in 4yrs.View attachment 861655
I see you have some galvanized fittings on your setup. I've read that galvanized fitting will shed the galvanic coating over time and will adversely impact high pressure fuel pump performance.
   / F3060 2 Micron Racor installation #19
It’s possible.
The fittings on left side is aluminum.
Aluminum must be fine to use since manufacturers use it in places where there is Diesel fuel.
I also remember having read something about galvanized fittings & Diesel fuel not being good combination so I've used brass fittings over the years.
For me 55 gallons usually will last 10 months, whereas some of you guys can probably use it up in one day...
2013 Ford Flex SUV (A50324)
2013 Ford Flex SUV...
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
4 Drink Hog Waterer (A50515)
4 Drink Hog...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
