F235 Starting problem
/ F235 Starting problem #11
Harry, make sure that the unit still plugged in , and that the wire to it just didnt fall off before you order one, a flashlight helps to locate it.
Ernie
/ F235 Starting problem #12
Ernie, in the pic I posted, did I located and ID the correct thing?
Ernie
"Those are not available new right now. Most customers just put on a standard pull cable like all of the other Yanmar models. Those electronic shut-offs are very problematic."
This was the response I received from Hoye when checking on the fuel motor. Any problem you have experienced in following their suggestion?
/ F235 Starting problem #14
Bingo, you got it
/ F235 Starting problem #15
vietvetharry said:
"Those are not available new right now. Most customers just put on a standard pull cable like all of the other Yanmar s. Those electronic shut-offs are very problematic."
Harry, The one I have is for an f24, it mounts differently than yours
If mine goes on my tractors, I think I will go with the cable
Well.... go buy a cable and get that yanmar a going again !:D:D
Ernie, sounds like a plan. The ol' tractor seat HAS BEEN missing my butt!:rolleyes:
Ernie
THANKS ERNIE, MICKEY & HOYE PARTS,
I found the motor thanks to Mickey and followed your suggestion to check the wiring before I removed it to install a manual shut-off cable that Hoye suggested.
After I disconnected, cleaned & reattached the two wire connections to the motor, I had the most wonderful "whirling" sound and immediately the diesel fired right off.
A great feeling when the problem you have been fighting for a couple of weeks is remedied so easily. Even a dimwit salesman like me can follow mechanical advice when it is so expertly offered.
Tractor people, YEH!
btw Hoye now has a parts manual in English for the F/FX235. It was a big help is finding how the shut-off motor was attached.
CFG QK20R (A60463)
CFG QK20R (A60463)
FORKLIFT (A56857)
FORKLIFT (A56857)
Kubota Snow plow with subframe
Kubota Snow plow...
2018 John Deere CX15 (A60462)
2018 John Deere...
Sakai SW354 (A60462)
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
