F20D starter problems
/ F20D starter problems #1
wwrafter
Grand Ronde, Oregon
Yanmar F2210D
Everything was working fine than I went to restart and nothing.
I have cleaned the posts and ground wire, I have 12.7 volts at the starter solenoid but it won't turn over.
Any help or suggestions would be appreciated
Thank you
/ F20D starter problems #2
Aaron on Hoyes site goes over Testing and Replacing the Starter Solenoid. It's under his How to Video's.
/ F20D starter problems #3
Check voltage at the small terminal on the starter with the key in the crank position. Should be the same 12.7 volts.
/ F20D starter problems #4
check the safety on the clutch, or you can just jump the two wires on the clutch switch to bypass the clutch switch.
2004 Peterbilt (A62679)
2004 Peterbilt...
HD Quick Attach Grapple (A66408)
HD Quick Attach...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
3'6"x5'6" Aluminum pickup Roller Tray (A62679)
3'6"x5'6" Aluminum...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
2020 Kawasaki Mule Pro DXT (A62613)
2020 Kawasaki Mule...
