F1fuse on JD5425 keeps blowing
   / F1fuse on JD5425 keeps blowing #1
tshands
While cranking my 5425, I lost all power and traced it to the 20A F1 fuse , which repeatedly blows as soon as I turn the key. Thoughts qnyone? Thx in advance.
Tom Shands
   / F1fuse on JD5425 keeps blowing #2
There is a chance the problem is the thermistor sensor (thermistors are temperature variable resistors used as sensors.). On the thermostat housing there is a sensor that is connected to a two wire harness that goes to the injection pump; this is the "cold start advance" portion of the system so it starts easier when cold by advancing the timing.
When the sensor on the thermostat housing fails it shorts out and blows the fuse. Try unplugging it, replace fuse and see if it starts and runs. The part # is RE503242, if you are quick changing it, you don't have to drain the coolant, just make sure it's not hot at the time. You will want a pan under the tractor to catch the coolant, so as not too have to clean it up.
To comply with the exhaust emissions regulation, the timing of injection pump should be around 6 to 9 degrees before TDC. These timing values do not allow proper start-up operations when engine is cold. To ease engine start-up, a cold advance system gives to the injection pump a temporary over-timing.
When coolant temperature is below 50 C (122 F), the solenoid valve is activated and opens the cold advance circuit.
Many thanks. Will do.
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2017 Genie GTH-5519 (A53317)
2017 Genie...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
