F16d maximum RPM
/ F16d maximum RPM #11
Found these pics while surfing, so they are not mine, so looks like it the RPM should be higher.
While using my F18D today, max rpm appears to be 2550rpm
/ F16d maximum RPM
So I understood thar rpm should be higher. But how i should adjust the maximum rpm?
/ F16d maximum RPM #13
I would first make sure your tach reading is correct. Unless someone on here has an F series manual and is willing to share you may have to invest in one.
/ F16d maximum RPM #14
I have a F series user guide, what should i look for Winston?
/ F16d maximum RPM #15
Governor adjustment. But I don't think it will be in the user guide. I think he will need access to a repair manual. Don't know all this, just speculating. :2cents:
/ F16d maximum RPM #16
I would really not mess with governor settings until it is established the engine isn't running at the proper RPM. While it may not hurt anything to run it over rated speed, it cannot be better, either.
/ F16d maximum RPM
My reading is correct becouse before the repair the maximum rpm was 2500.
/ F16d maximum RPM #18
What repair did you do that may have changed the governor setting? I don't have any information I'm not sharing, but if you did something that may have changed how the engine runs, I would go back and assess that first.
The other thing to try is to manually move the throttle lever where it enters the injector pump or governor and see if the linkage isn't delivering full movement. There may be a stuck pedal, bent piece of linkage, or something else that is keeping you from getting full throw on your throttle control.
/ F16d maximum RPM
The fuel pump vas cleaned. I adjusted the screw near the pump, so I believe I should adjust it again, but I don't know how to adjust it.
/ F16d maximum RPM #20
I take fuel pump to mean injection pump? Why was the pump cleaned? Sticking? Picture of the screw possible? Did the screw have a cap on it? Have you tried slowly moving the screw closely watching the results? Don't guess you have if the tractor is not in reach until spring.
The group of parts associated with ref 16 in the parts drawing is the limiter shaft assembly on a 1510. Your screw anywhere around that area? http://www.hoyetractor.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=HTE&Category_Code=YM1510GOV
1611 (A57192)
1611 (A57192)
Kubota L4701 (A53317)
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
Massey Ferguson 4707 (A60462)
Massey Ferguson...
