F150 Suspension
/ F150 Suspension
I'm not going to make a major size upgrade in the tires. It has 265/70/17s on it now. I'll probably go with a 275 or 285, nothing that requires any suspension mods.
The way I look at it is to start basic and simple. It will need new tires in another3-4K miles. The cheap-o shocks on it now are pretty long in the tooth as well. So I'll start there. If new shocks don't help, nothing lost really.
/ F150 Suspension #22
Poly bushings would probably tighten it up a bit, but not a whole lot. They definitely are not as squishy as the factory bushings/bumpers.
I would add caution to picking shocks. My old F250 needed shocks. I got the super-duty Monroes. They worked really well. But, the overall effect was stiffer than a 2x4. It was great with the camper or other heavy load, but not empty... That's why I went with the Rancho adjustables in the end. Previously I had mediocre luck with Rancho RS5000's. But, thier RS9000 worked awesome.
/ F150 Suspension #23
N80 said:
I appreciate the advice but I don't think you read my post right, or at least I didn't make my point well. First, there is nothing car-like about the ride of any of the Nissan or Toyata trucks I've owned...at least not prior to about 1995. Second, its the F150 that rides more like car. And its made that way because that's what most F150 buyers want, even the one's who buy 4wd. It's great on the highway, sorry off-road. But I'll concede that the springs might be quite firm (it rarely bottoms out even when hopping along a trail). But that really isn't the issue. The problem is that they seem to be too lightly damped. If you recall from the original post, the issue that I'm having problems with is that once you hit a bump it just keeps on bouncing and bouncing. I don't mind the initial bounce. The continuous bouncing also dimishes control.
Removing the front anti-sway bar would greatly amplify the problem of 'sway'. The thing rocks like a dingy in a storm as it is. And I understand that shocks dampen oscillation. But they will dampen any oscillation, even if it is from the truck rocking side to side. So better shocks will surely help.
Of all the options I think either the Bilsteins or the Ranchos look best to me.
When I wasting money on hopping up my Nissan years ago, someone made firm polyurethane (or something) bushings to replace the rubber ones on the front anti-sway bar (and shocks). It seemed to help but it was probably my imagination (kind of like when your truck seems to run better after you wash it.) ;-)
But just to make it clear, I'm looking for firm _and_ responsive, which is what I consider a 'real' truck. I'm trying to get away from wallowing and unending bounce.
hmmm, ok.. Well good luck with it... Most of the complaints I have heard of the new F-150 is that they are too firm and have too much feedback(on and off road) because of it..The time I have spent in them dictates that as well, in my perception..But, I guess I did missunderstand you.. My '94 F-150 has 18" of wheel travel(fairly soft springs) and can quite quckly cover rough ground with a comfortable ride, sorry, thought thats what you were after..
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2019 John Deere R-4038 (A63688)
2019 John Deere...
2022 Deere 317G (A64126)
2022 Deere 317G...
8' DISC HARROW (A60430)
8' DISC HARROW...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
2011 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2011 GREAT DANE...
