F150 Recall
/ F150 Recall #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Looks like Ford is recalling over 2 million F150's. There is some kind of device that fires off if you get in an accident to tension the seat belt. This can start a fire in the B-pillar area and burn the truck to the ground. Sounds like it affects regular cab and crew cab trucks built from 2015 to the present. I have a super cab and it appears it doesn't need recalled since there is no B-pillar on the truck.
/ F150 Recall #2
Wow! Totally amazed here - a recall that does not affect my 2005 F-150.
/ F150 Recall #3
More amazing, a recall that isn't for one of my RAMs.
/ F150 Recall #4
Ain't that the truth. I currently have 2 recalls I need to get taken care of on my Ram. One for the fuel tank strap and the other for the park interlock pin.
/ F150 Recall #5
I just scheduled the recall work on my 2018 Supercrew at my dealer for next Friday. When the recall came out they said they couldn't even sell a new F150 until the recall work was completed on it. I am still kind of amazed at having an explosive device in the seat belt mechanism :eek:.
/ F150 Recall #6
kf4uda - Chris - I would bet its the same type explosive device you will find in your air bag also.
/ F150 Recall #7
Sung up the seat belt just before firing off all those air bags at you. Found a bunch of airbags when I ran the dash cam wiring thru the pillar and headliner.
That is 3 ford recalls I need to get done. My 2016 F150 has new flaming seat belts and the misbehaving door latches. My wife's car has the shrapnel air bag (passenger side).
/ F150 Recall #8
My 2005 F-150 has some kind of recall on the airbag wiring harness. First notice - seven years ago. After being called THREE separate and different times - to come on down and get this fixed - showing up and Ford having no idea why I was there - they DID NOT have the repair parts. I sent them a registered letter - asking that they discontinue sending me these false alarms. Haven't heard from them now for over three years. I expect they will NEVER get the repair parts and I will NEVER again receive a recall notice. Life is good.
2008 Mercury Mariner (A62679)
2008 Mercury...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
