F Series vs. ZD
   / F Series vs. ZD #111
I more about 4 acres of bumpy lawn full of obstacles with a Toro Z master 2000. 3 hours max.
   / F Series vs. ZD #112
Late to the game but my F Series Kubota diesel front mount 72" mower rides like a Caddilac. It came with an air ride seat...lol My wife has a ZTR but I now prefer the steering wheel over the oars.
   / F Series vs. ZD #113
I have posted before changing ZD331 to Grammer air ride seat. It is a game changer on rough grounds
My Stihl ZT takes the opposite approach to rough ground. The seat is the standard spring suspension, but the machine has 4 wheels spring/shocks suspension. It rides very well on rougher ground. Since I mow native grass around the house/ outbuildings and not lawn, this was almost a necessity for my needs. The remainder of the property gets cut with the tractor and rotary cutter.
   / F Series vs. ZD #114
All I know is, when I run my wife's zero turn (which is infrequently), our lawn is bumpy as well and that bumpy yard equates into a rough ride whereas the Kubota front mount mower rides like a luxury car. At my age I much prefer a smooth ride over a rough ride. I also prefer a diesel engine over an air cooled aluminum block V twin for longevity and fuel efficiency. None of the current V twins made today will outlast the diesel. On the contrary. The will puke long before a diesel will.
   / F Series vs. ZD #115
I also prefer a diesel engine over an air cooled aluminum block V twin for longevity and fuel efficiency. None of the current V twins made today will outlast the diesel … They will puke long before a diesel will.
I totally agree.
Gassers rev too hi causing too much vibrations & NO TORQUE in tall grass OR pulling steep banks.
   / F Series vs. ZD #116
The pot metal that the motor blocks are cast from (high pressure die casting) that make up today's V twin and single cylinder motors used in lawnmowers and zero turns aren't made to last like a nodular cast iron block and head of a diesel engine. Basically, disposa motors, all of them.
   / F Series vs. ZD #117
I have about 5-6 acres to mow.
I don’t have many hills but I’m struggling to rationalize 20k on a piece of equipment that only does one thing. At the same time I don’t want to compromise.
Forest. Forest Gump.
Embrace your new lifestyle. If you are balking at $20K then you really should consider selling that property. You will be paying far more than that maintaining 5-6 acres of lawn.
   / F Series vs. ZD #119
… I’m struggling to rationalize 20k on a piece of equipment that only does one thing …
I’ve learned in my old age that a one trick pony does it’s one particular job WELL.
It’s more efficient & doesn’t compromise any at all.
Equipment that does various jobs doesn’t shine bright in any one category.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
