F.E. Myers Air Blast Orchard Sprayer Information
   / F.E. Myers Air Blast Orchard Sprayer Information
Ok, so I was able to source a set of NOS Myers piston cups. They are a whopping $92 a piece. I was able to get the OD dimensions of the original units which is 2-3/16”. That seems to track with them being a little tighter than they currently are and how much they have potentially worn. The units from abroad are 2.25” making the difference between them, .0625”. I am betting that I can mount the cups in there “mounts” and shave off .0625 on my lathe to make them 2-3/16”. Thoughts?
   / F.E. Myers Air Blast Orchard Sprayer Information #132
Could you post a pic of these piston cups? Alternatively, could you sand off 1/16" off those piston cups?
   / F.E. Myers Air Blast Orchard Sprayer Information #133
These are mine
Here is a photo of the units from overseas. There are 2.352" so my math is a little off from my previous post. The amount that would need to be removed is 0.1645", a little more than 1/16", but not by much. Sanding the cups could be a good way to go about it, but is there also a way to make/keep them smooth?
   / F.E. Myers Air Blast Orchard Sprayer Information #137
Are the imported cups cheap enough you could experiment with one on reducing the diameter on your lathe?
   / F.E. Myers Air Blast Orchard Sprayer Information #138
It looks to me like the cheap overseas cups have a thinner wall than the correct OEM cups to begin with. The other issue it looks like the internal diameter of the Chinese cup is bigger than the correct OEM cup. I think its important that the securing nut fits the inside diameter of the cups to give support to the cup walls. I think you’d be back to where you are now with a leaking pump.
I’d buy the OEM cups and be done with it. It’s not like you’re going to be changing them out once a season, with proper care they should last you many years especially since you’re only spraying 6 acres few times a year.
Given the price point of the overseas units, I am probably going to buy both. I would experiment with the overseas units to see where it gets me. I would also make an offer on the NOS units. Let's see what happens!
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2003 Honda Element SUV (A55758)
2003 Honda Element...
MMS Jaw Crusher (A53316)
MMS Jaw Crusher...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
