F.E. Myers Air Blast Orchard Sprayer Information
   / F.E. Myers Air Blast Orchard Sprayer Information
Ok, so I was able to source a set of NOS Myers piston cups. They are a whopping $92 a piece. I was able to get the OD dimensions of the original units which is 2-3/16”. That seems to track with them being a little tighter than they currently are and how much they have potentially worn. The units from abroad are 2.25” making the difference between them, .0625”. I am betting that I can mount the cups in there “mounts” and shave off .0625 on my lathe to make them 2-3/16”. Thoughts?
   / F.E. Myers Air Blast Orchard Sprayer Information #132
Could you post a pic of these piston cups? Alternatively, could you sand off 1/16" off those piston cups?
   / F.E. Myers Air Blast Orchard Sprayer Information #133
These are mine
Here is a photo of the units from overseas. There are 2.352" so my math is a little off from my previous post. The amount that would need to be removed is 0.1645", a little more than 1/16", but not by much. Sanding the cups could be a good way to go about it, but is there also a way to make/keep them smooth?
   / F.E. Myers Air Blast Orchard Sprayer Information #137
Are the imported cups cheap enough you could experiment with one on reducing the diameter on your lathe?
   / F.E. Myers Air Blast Orchard Sprayer Information #138
It looks to me like the cheap overseas cups have a thinner wall than the correct OEM cups to begin with. The other issue it looks like the internal diameter of the Chinese cup is bigger than the correct OEM cup. I think its important that the securing nut fits the inside diameter of the cups to give support to the cup walls. I think you’d be back to where you are now with a leaking pump.
I’d buy the OEM cups and be done with it. It’s not like you’re going to be changing them out once a season, with proper care they should last you many years especially since you’re only spraying 6 acres few times a year.
Given the price point of the overseas units, I am probably going to buy both. I would experiment with the overseas units to see where it gets me. I would also make an offer on the NOS units. Let's see what happens!
1999 Talbert T30W-50SA-HRG-1-T1 (A47477)
1999 Talbert...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
Unverferth Gravity Wagon (A50775)
Unverferth Gravity...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2005 Kaufman Trailers Car Hauler Trailer (A55788)
2005 Kaufman...
