Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 26,567
- Location
- The Last Red State in the Northeast
- Tractor
- Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
Been looking around at leaf clean up options for large acreage on a limited budget. Blowers, vacuums/mulchers and sweepers seem to be the majority of options.
Running a Kubota ZD331 with 72 commercial deck.
Large area blower is pretty much out because of the complexity of the buildings, beds, parking areas, etc. too many objects to blow around in this housing complex. It would be a push type and not looking forward to doing all that pushing :laughing:
Vacuum/mulcher seems pretty good, but thousands of dollars. This will be the eventual way to go in the future, but as of now, I think it has to be a sweeper.
I do this housing complex 2X per year and a few other small places, so only talking about maybe 6 days a year of usage.
I have the ordinary large (48”) Agri Fab yard sweeper. I grind up the leaves and simultaneously pull the leaf sweeper. Works ok, but homeowners + at best build quality.
Do any of you have a larger, say 60 or 72” sweeper, with a commercial build quality I can pull behind a ZD 331 to pick up leaves?
I would think this would be an inexpensive, relatively good results way to go. Cheaper by quite a bit than a vac system where a second gas powered engine is required (can of gas, engine maintenance, more moving parts) as compared to a sweepers simplicity.
