EXTERNAL MIRROR INSTALL
/ EXTERNAL MIRROR INSTALL #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
One of my complaints about the cab tractors is you can not see if you are spinning your rear tires very well. I installed the external mirrors and adjusted them so that now I can see what my rear tires are doing. You can also see any rear implements fairly well.
/ EXTERNAL MIRROR INSTALL #2
I have mirrors and like them a lot,did you mount them inside or outside of the arm that holds the mirrors,I mounted them inside the arm so the trees can break them off a replacement glass part cost $72.00 just the glass.Buy the way if the a tree branch folds back the mirror arm get out and fold it back before they both get folded back or you can not get out of the cab with out going out the back windiow.
minimax
minimax, thanks for the tip on exiting the cab if the mirrors get folded back. Is that the voice of experience?
/ EXTERNAL MIRROR INSTALL #4
Yes that is the voice of experience,mowing walking trails and got both folded back and was thinking that I would push the mirror out with the door no way,Had to have somebody else pull the mirror out! If they stick out to far you can fold them forward.
minimax
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2022 Ford F-150...
2004 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2004 PETERBILT 379...
