extend PTO shaft
/ extend PTO shaft #1
jimmysisson
W.Mass
1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
Anyone welded on an extension to the 1" square male portion of a PTO shaft? I have a new-to-me implement and I need to add about 4" to the overlap. I think I have an old piece somewhere. The rest of the shaft and yokes and crosses are good. As long as it's straight when complete, should be fine, right?
Thanks, Jim
/ extend PTO shaft #2
If you have internal support and make very pretty welds, you should be fine. I prefer a sure thing, so I'd simply replace the shaft with appropriate length. If you plan to use that same shaft with other implements, be sure that your mod doesn't make it too long for those other devices.
/ extend PTO shaft #3
for 4 inches I do not see a problem is the welding is good, (most likely if 4 inches is all you need) you will not even be using the section that is welded. it is more for keeping the shaft together,
/ extend PTO shaft #4
TSC has PTO extenders that fit onto the tractor's PTO stub. Looks like they come up to about 10" even. If the implement has a PTO type spline on the gearbox, you can place it there.
I'd recommend an extender over a welded section to preserve the shaft's usefulness and prevent all likelyhood of it binding up.
/ extend PTO shaft #5
/ extend PTO shaft #6
This is the reason god made MIG welders. Taper the sides. If you have a lathe drill a hole for a pin to line it up perfectly. I have done this before and never gave it a thought. Unless your talking in excess of 100 hp its as good as new.
/ extend PTO shaft #7
Unless you are a highly skilled, certified welder, with a good working knowledge of the steel you'll be joining and it's heat treatment, i would go with the store bought extenders, as suggested by Roy. No sense risking complete shaft damage to save $20.
/ extend PTO shaft #8
Yes... Were building space ships here. Break out the titanium. Sounds like the college professors approach to buying a candy bar. One inch of steel encased in another half inch of steel. Whats the calamity if should fail in twenty years ? It is great there are consumers that wear a million dollars of life insurance and check their computers for rain before stepping outside ... but for the most of us " dare devils " live for expanding our knowledge and learning abilities. Why would I buy a six thousand dump trailer when I can build one for much less, and use my choice of updates ? There will always be buyers and builders. I built five homes by myself...... my mistake. I should have hired a professional and shouldering a huge debt .
Something as simple as a small square shaft, take a chance in life. Do something with satisfaction. Stir the creativity that rests in the back of your brain and most of all have fun. The best therapy in the world awaits the person standing over a pile of scrap metal.
/ extend PTO shaft
Thanks for all comments. I will mig the extension tubing and keep an eye on it.
/ extend PTO shaft #10
Nice. Glad you feel comfortable telling the OP to just do it when you know nothing about the circumstances. But then, you've got no skin in the game.
2016 Yanmar Vio45 (A60462)
2016 Yanmar Vio45...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
SDlanch SDLGC80 (A60463)
SDlanch SDLGC80...
iDrive TDS-2010H...
2005 Sterling Acterra Tender Truck (A61307)
2005 Sterling...
1986 MURRAY WEST COAST STYLE RGN (A60736)
1986 MURRAY WEST...
