extend PTO shaft
/ extend PTO shaft
It turned out the original shaft was 1" square solid, not tubing (I hadn't looked at the end, just the overlap). So, ground in a vee and mig welded a couple of passes.Also tried to extend the shallow grease trough so the lube might work its way in both directions.
I beat on it with a 2# hammer and it rang solid, so ground the welds flat.
It was a bit tight going into the female end, so ground off the corners a bit.
Then it slid home and works well - there must have been a bit of flex before as it's smoother now. The welds aren't perfectly solid, but I got good penetration, I think. Clamping everything to a chunk of iron and opposite-side tacking helped keep it straight. Any comments on the welds?
Jim
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
1999 John Deere 7810 (A60462)
1999 John Deere...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
John Deere 2025R (A64126)
John Deere 2025R...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
