Experience with Tank-less water Heaters
/ Experience with Tank-less water Heaters #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
We are about half way to closing on our new house. I want to convert to a whole house tank-less WH and looking for voices of experience. will be natural gas direct vent condensing type. I have boiled it down to 3 brands; Rheem, Bosch, and Rennai in their top of line. I am more interested in life and problems than cost.
Who out their has experience with these brands? How long has it been in? Problems? Would you recommend it to your best friend? Any help will be appreciated. Thanks in advance.
Ron
/ Experience with Tank-less water Heaters #2
Ron
I had a house with a rennai, loved it. After doing my own research, I will be installing another in our new home.
Word of caution. Tankless water heaters does not mean maintenance free. It is highly recommended to flush the heater once a year. A very simple procedure especially if you plan ahead for it.
/ Experience with Tank-less water Heaters #3
I have had a rennai for going on 2 years. Not one problem. A good friend has a rennai for over ten years and not one problem and never has flushed his as of yet and he recommended it to me several years ago. It's like he said to me you can fill up a Olympic swimming pool and not run out of hot water. My gas bill went down from over sixty dollars a month in the summer to under 20. Heating water is the only gas used in the house during the summer. I didn't get the cheapest one and it has a better water flow, I think the cheapest one was like 7.5 gallons per min and the one I got is like 9 gpm. It was preset for max temp of 125 but you can flip a dip switch or two and run it up to 145 I believe it is. I have it set to 130. Should have gotten one years ago.
/ Experience with Tank-less water Heaters #4
I have a Takagi. 2 yrs old and the heat exchanger started leaking. I went for warranty repair and they sent me a new one with instructions on how to replace (NOT easy!!) and told me to send them photos of the old one when it was out. Did that and they told me they were giving me the exchanger as a goodwill gesture, but that they would not warranty the heater for this again, as it was caused by hard water. I was a bit shocked that they could tell this from the photos, but apparently they have seen this a million times. They didn't need it back so i cut it open to see. There were some thin deposits on the inside of the tubes which is apparently all it takes to ruin these things. What happens is the minerals deposit on the walls and build up. This insulates the water from the flame and causes the exchanger to overheat locally, which eventually leads to a leak. Here's the rub. We moved in Aug without a water softener. It quickly became obvious that we needed one and finally got it in place in Nov. Water was around 20 grains hardness or so, IIRC. That was all it took to ruin this thing. Just 3 months. Now if I had acid flushed it somewhere in there to remove the minerals, that may have solved it, but my idiot plumbers did not put a flush valve kit on it. I added that when I had it down for the exchanger swap.
With all that said, I love it. But it is clear that you need to be super careful about water hardness going into it. Also when you install these, make sure you put a flush valve kit on them so you can easily maintain the unit. Like this thing: 44443WPR - Webstone 44443WPR - 3/4" IPS Isolator E-X-P E2 Tankless Water Heater Service Valve Kit (Lead Free)
/ Experience with Tank-less water Heaters #6
Search TBN for more discussions about tank less water heaters. There have been a few and seems like some discussions were quite long.
We thought about putting in a tank less water heater but we decided against it for a couple of reasons.
  • It would have to be electric and the temperature rise was iffy.
  • It was far cheaper to have an 80 gallon water heater.
  • The 80 gallon water heater is a nice source of water if we are out of power.
Years after we moved into our house, we were talking to our plumber. He said he now refuses to install a tank less water heater since he had so many problems with them. The big problem was water hardness. So if you do put in a tank less water heater, I would make sure the water supply was in spec for the heater. Hopefully the tank less water heaters specify water quality.
Later,
Dan
/ Experience with Tank-less water Heaters #7
You need to ensure you know what your recovery rate is and at what water temp.
It IS possible to actually run out of hot water with a tankless heater if it isn't sized properly.
If you're on well water, due to scale build up, you'll want to clean the heat exchanger at least once a year.
If I lived back up north, I'd probably go boiler with storage tank. Best of both worlds although a lot more money.
/ Experience with Tank-less water Heaters #8
+1 for Rinnai - we had a LP exterior mount installed when our house was built. Our one unit is capable of supplying enough water for our house and guest house. We love it - consider exterior mount if your climate allows for it. No need to worry about venting.
/ Experience with Tank-less water Heaters #9
Well, I have an odd brand tank-less water heater, Quietside. Going on almost 5 years now. Never been flushed and never had a problem. Operates on Propane. Residential natural gas is not available in my rural area. Also have a Peerless high efficiency, direct vent boiler for hot water baseboard heat. Very happy with both. Cost of operating varies with the price of Propane.
What we really love about both, we can still have hot water and house heat when using our generator during storms and power outages. :)
Couldn't do that in our old house with an electric hot water tank and electric baseboard heaters. It would have required a much larger generator at a prohibited cost for us.
/ Experience with Tank-less water Heaters #10
There is a huge difference between NG/LPG and electric whole house tankless units. It is very hard to find a reliable electric tankless unit unless things have changed in the last few years. I remember researching them and even one of the most highly rated ones had serious issues. One apartment manager bought 24 for use in his apartments. Within 1 year, 32 had been replaced. Yep, some had been done more than once. I can not remember if it had a 3 or 5 year warranty but he was expecting to replace them many times. On the plus side, he had it down to a science from doing it so many times and he could replace them relatively quickly. The smaller single faucet electric ones seem to have fewer issues.
Ken
/ Experience with Tank-less water Heaters #11
Another good vote for for Rinnai. We had a NG unit installed in our (wife and I) new home's garage which we took possession on 11/15. The water heater has been 100% reliable and our NG bills are small. Another consideration is installing multiple smaller units if the size of the house warrants it due to long pipe runs and wasting a lot of water waiting for the hot water to get to the faucet.
/ Experience with Tank-less water Heaters #12
Later,
Dan
80 gallon electric water heaters are no longer available for residential use unless they are heat pump units, and that's a whole other discussion.
/ Experience with Tank-less water Heaters #13
We have three Rheem LP units, one is about 3 years old now and the other two are about 4 months in use. I love them, cheap, efficient and endless hot water. It is very important that you flush them with vinegar or similar solution to remove the scale. All three of our units have the service valves that make this procedure simple. The upfront cost is high but the long term value is there.
/ Experience with Tank-less water Heaters #14
Either LP or NG gas type Bosch and Rinnai gas type i am familiar with and both are good units. Just go ahead and get the flush valves installed when the unit is installed. Its so much easier and simpler to do so at original install.
Probably does not matter at this time but just so you know some areas are beginning to require high efficiency hot water heaters and some Hvac units to have the condensate drain go to a separate drain point, usually a very small gravel pit near the edge of the house. The ph is so different they do not want them draining into the septic system or the municipal treatment plant. I think this will become national code in a few years from what I am told.
/ Experience with Tank-less water Heaters #16
Thanks a lot for all the info. This has narrowed my choice to Rinnai or Rheem. They are close to the same price for the top of line; high, but this is a long term investment.
Ron
just an FYI. Most all of them are made / use with the same components. Not a nickles worth a difference in any of them
/ Experience with Tank-less water Heaters #17
Ron
We've had a Rennai for over 6 years. When we bought this place (3000 sq.ft.) we had a brand new electric water heater jerked out and replaced with a propane/electric start tankless heater. Best move we've ever made. Endless hot water, no idle time heating cost, and essentially maintenance free. The unit cost us $1600 installed.
Ours is mounted on an outside wall near the bathrooms. No venting problem and never have had a freezing problem... Having hot water for a quick shower is actually 'quick'. As far as maintenance, ours has two bypass plugs to take out, run the water a few minutes through it to flush any residual that might be in there, and replace the plugs. Very simple process that we do about every couple of years.
My only two suggestions are that when you do have it installed, try to locate the unit as central as you can conveniently locate it. AND - add a small unit under the kitchen sink. Wife doesn't like to wait 30 seconds for hot water to go from the unit to the sink. The little one location unit is only about 1 foot square and cost a couple hundred dollars. They also only use 120v electricity to spark the heating coil. Low cost for a happy wife :)
/ Experience with Tank-less water Heaters #18
Ron
Make sure you order the service valves with them, they make de-scaling the units so much easier.
/ Experience with Tank-less water Heaters #19
We have a Noritz that is 7 years old now and installed the recommended filter with it. The filter needs to be changed every3 years and is around $ 125. The only problem we've had is one of the wires from the control panel to the computer apparently vibrated loose causing an intermittent fault message .
Ours is used as back up to our solar water heater and so far is very satisfactory.We would never go back to the old tank type heater.
/ Experience with Tank-less water Heaters #20
-1 for Bosch and + 1 for Rinnai
First installed a Bosch. It was still under warranty when the control board failed. I called their support line multiple times, they asked me to do lots of stuff to test. In the end they called it "electrical failure at customer's home" whatever that meant and refused to honor their warranty. Mind you, nothing else failed in my house and the electrical part of the unit was a simple plug in to an outlet. Replacing the control board would have cost me $800. I decided to scrap it instead and replaced it with a Rinnai. Haven't had a lick of problem since. There is a reason why there is no Bosch service guy in my little town while I can find several outfits that will service Rinnai systems.
