Excavator, swap pilot lines
   / Excavator, swap pilot lines #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I have a Komatsu PC75 excavator and I want to change the controls from ISO to SAE (backhoe). This is a pilot-operated machine, so this should be easily done at the valve stack. The question is how can I figure out which lines I need to swap? This machine has 9 spool sections so the valve stack is almost 2' high. Any suggestions would be appreciated.
   / Excavator, swap pilot lines #2
If you can get an accurate hydraulic schematic it should identify which valve section controls each function.
If no schematic then you are going to have to make your own by following hoses from joystick to valve sections and hoses from valve sections to function they operate.
Then hope the pilot hoses are long enough to allow you to move them.
   / Excavator, swap pilot lines #3
I’m m surprised it doesn’t have a change over valve.
   / Excavator, swap pilot lines #4
I agree. Surely it has to have a pattern change valve. Specially a machine this size.
Best I can tell, it does not. I was planning to add one.
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
John Deere (A50322)
John Deere (A50322)
2017 Ford F-250 Enclosed Knapheide KUV Service Truck (A50323)
2017 Ford F-250...
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F450...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
