Exactly what is 'shuttle shift'
/ Exactly what is 'shuttle shift' #1
jeffgreef
Plumas County, California
Farmall, Gibson, Windolph, Simar, Bear Cat, Vaughan, Howard
I'm a bit confused about the different transmissions that have names like 'shuttle shift' and other similar names.
Basically, do these allow to shift from forward to reverse without using the clutch? Why doesn't this grind the tranny? Are there different types with different capabilties?
I'll need to do a lot of back and forth with what I buy, but if I don't have to get a hydro, maybe I won't.
Is shuttle shift good for back and forth FEL work?
Thanks in advance for the benefit of your knowledge and experience.
JG
/ Exactly what is 'shuttle shift' #2
Shuttle shift does indeed allow you to go from forward to reverse in whatever gear you're using. It generally does require the use of clutch. The big advantage is that you then have multiple reverse speeds as compared to other models that may have 1 - 4 forward + reverse. (I'm thinking 9N here). This is good for loader work - however I've found hydraulic drive to be far better.
Mike
/ Exactly what is 'shuttle shift' #3
JG
Powershuttle does not require the use of the clutch when switching from forward and reverse. It is the way to go, if you are constantly changing directions.
Sync shuttle requires the clutch.
I say go Powershuttle. You choose the range, gear, and then you just shuttle all day long. You also have multiple reverse gears, in our case 12F, 12R.
Keep us posted.
/ Exactly what is 'shuttle shift' #4
shuttle shift does allow back and forth shifting without using the foot clutch and so is very conducive to loader work. There IS a clutch, but it is moved electronically, which is why there gears don't grind. There's usually a column shifter that you use to toggle direction after selecting what gear you want to be in. I also believe you can shift gears "on the fly" without using the foot clutch. (Someone jump in if I'm incorrect on this, I don't have a shuttle shift myself). Kubota's model is the GST and it's about the same price as an HST. Kind of getting the good qualities of a gear (more hp to ground), along with the good qualities of an HST (quick and easy back and forth movement). What it doesn't give you is the infinitley variable speed of an HST.
/ Exactly what is 'shuttle shift' #5
JG
On my Kubota the shuttle shift lets me go from forward to reverse smoothly with out using the clutch ( takes some getting used too ). I am told this is accomplished with electrically actuated wet clutches, which SHOULD mean long life of all the clutches.
I have done a lot of grading & FEL work with it and am very happy so far.
E/S
/ Exactly what is 'shuttle shift' #6
There are a lot of shuttle shift transmissions that you must use the clutch when ever you are shifting F-R, up or down. I would guess that it is usually a higher end option that gets you a shuttle shift trans that does not require manually engaging the clutch.
/ Exactly what is 'shuttle shift' #7
I have a MF 3e. It is an industrial TLB 49hp. It has a shuttle shift. No manual clutch at all. 4 speed transmission.
Brakes on the left. Two pedals on the right one pedal is forward , the other is reverse. The further you step on the pedal the faster you go. Electro mechanical wet clutches integrel with the transmission. If you step on both pedals at the same time you get rpm increase and no motion. Works great for FEL . There is a hand throttle for the hoe.
/ Exactly what is 'shuttle shift' #8
There are enough different types of "shuttle shift" to drive you crazy.
Mine has a 4 speed transmission with the typical "H" shift pattern, plus a "shuttle shift" that lets you select either Hi or Lo range forward, or reverse, for a total of 8 speeds ahead and 4 in reverse. All require use of the clutch when changing. Low range ahead and reverse are opposite each other, it makes for easy shifting back and forth.
I find the shuttle I have works fine for loader work, I use 2 or 3 in low range for heavier stuff like soil, and 4 in low range for snow. 1 is good for delicate stuff (small movements), while high range is used for either transport (3 or 4), or bush-hogging (usually 2 or 3 high).
Chilly
/ Exactly what is 'shuttle shift' #9
Shuttle shift or Syncro shuttle usually needs the clutch to forward/reverse
Power shift or Glide shift usually means you can forward/reverse without clutching.
/ Exactly what is 'shuttle shift' #10
That description sure sounds like a hydrostatic transmission to me...I have never heard of a infinitely variable shuttle shift before:confused:
/ Exactly what is 'shuttle shift' #12
I have a question, you say that your MF 30E is a shuttle shift, ( usually a forward, reverse lever) and yet you have two peddles on the floor for F & R. If indeed this is the case, what is the actual purpose of the shifter? :confused::confused: :eek:
/ Exactly what is 'shuttle shift' #13
I have an HST on another tractor. This is not that. Maybe I said it wrong.
When you step on the pedal it first picks a solenoid that engages the wet clutch for direction and as you push the pedal further the engine rpm increases by a mechanical link to the injection pump.
The shifter gives 4 different speeds . They must be sycro because I can shift on the move if I let off the pedal . That drops the clutch.
thanks guys very helpful as usual
JG
/ Exactly what is 'shuttle shift' #15
You got that right. You pretty much have to look at what the maker
means when they use a trade name for a tranny type.
Just within the Kubota brand, I believe their big daddy tractor back in the
70s, the L355SS, used the term "shuttle shift", and I suspect that it
was unsynchronized. My L2550 had a FWD/REV shuttle control on the
column, too, and it was not synchronized. I suspect that your L3400 has
a synchronized shuttle control. All require clutching before shifting.
Kubota's GST (Glide Shift Trans) came out about 1990 and was a totally
different beast where the FWD/REV shuttle control did NOT require
clutching.
/ Exactly what is 'shuttle shift' #16
While there are many types of transmissions and clutching conditions, does not the term shuttle shift really indicate that some sort of lever has to be moved in order to change directions, Regardless of if you have to clutch or not or stop or not, you still have to move a lever of some sort to change direction. How many gears (speeds) forward that you have, you have the same amount in reverse. I believe that any tractor that has this lever (Johnson bar for old timers) would be considered a shuttle shift transmission.
/ Exactly what is 'shuttle shift' #17
I think that if you are using the term "shuttle shift", uncapitalized, that
makes sense. However, if it is a trade name, "Shuttle Shift", the maker
can mean different things. Same with other terms that may or may not
be generic, like "Power Shift", "Power Shuttle", etc.
Even less precise is the term "Gear" transmission.
/ Exactly what is 'shuttle shift' #18
I have a JD 3520 with the Power Reverser transmission I chose mostly for loader work and trimming hedges, both requiring numerous shifts from forward to reverse and back. The small orange lever (red arrow) allows you to switch from one to the other with a flip of the left hand without ever using the clutch. It uses a separate automatic hydraulic clutch (picture 2). And you can choose what you want from the 12 gears either forward or reverse (but cannot shift gears without clutching, which is very sedom necessary).
/ Exactly what is 'shuttle shift' #19
Hey Jeff,
We've got both a Hydro and a shuttle shift, when I am doing a lot of close in loader working or a lot of front and back work I prefer the Hydro for the close in work. The Hydro is easier to control when I am working up close to things. I really enjoy the T2220 Hydro when I am doing loader work.
With the winter time I've been using the DX60 with the shuttle shift more. I'm still nervous getting close up to things its a little more work. On the DX60 I've got a high, mid, low range down beside the seat, on the right side of the dash I have a H pattern 1-4 gear shifter, on the left side of the dash I have a forward-reverse lever.
To select my H-M-L range or my 1-4 gears I have to use the clutch, but then I let the clutch out and then just use the lever to go forward or backward. The shuttle shift is very smooth in start ups, you can hit forward to reverse on the go also, the tractor slows down and then just takes off the other direction very smoothly.
It's nice to spend the afternoon moving snow and never having to do any clutch work. Also for cultivating it is nice using the Shuttle shift and not having to press a pedal for speed all day long. Hope this helps.
/ Exactly what is 'shuttle shift' #20
Like my MF390..manual trans with 12F/12R and a mechanical shuttle that requires clutching.
