EX3200 CL300 loader converting to SSQA
/ EX3200 CL300 loader converting to SSQA #1
MAINLYTRACTOR
Wiscasset,ME
Kubota L3240 CAB TLB /2020 John Deere 3033r Cab 2019 JD 920M
Has anyone converted their conventional pin on bucket to a skid steer quick attach. Looking for some pictures or ideas took some measurement and the cl300 loader is a actually wider that a skid steer plate not by much just enough to make my life difficult I purchased so plates and SSQA adapters attaches is what I bought as well as what I’m thinking I might have to fabricate. Any advice or help would be appreciated
/ EX3200 CL300 loader converting to SSQA #2
My 1998 New Holland 1925 tractor did not come with a quik attach, but I ordered one after market so I could use a set of pallet forks. Also ordered two plates from the same place (ATI New Holland, PA Tach-All Quick Attach, Loader Attachments, ATI Corporation )because I had two different buckets (one went with the NH when I sold it, I kept the other one) I cut the brackets off that held the normal pins, and welded the plates on in place....wasn't a huge job.
Later, current Yanmar 2011 with CL 300 loader meshes right up with that plate, as well as the bucket that came with the tractor and the after market pallet fork plate. Also bought a front bale spear that has the SSQA plate on it...meshes right up.
I thought SSQA stuff was standardized....you're saying the Yanmar QA is wider than the plate ? Maybe whoever made the plate missed it ?
Currently have a pin on style bucket but the width of the actual loader is almost exactly the width of a skid steer plate. Not much I can do for mounting brackets to ssqa pre made plates
/ EX3200 CL300 loader converting to SSQA #4
Interested in this. I would like to do the same to my ex3200
/ EX3200 CL300 loader converting to SSQA #5
OK....I take it you do NOT have an SSQA male part on your tractor now, since you're using a pin on bucket.
If you'll notice the adapter that goes, and stays, on the loader, the 'male' part, with the 2 throw handles, that connects with the plate on the bucket/forks/etc is narrower than the pin position on the loader.
See the photo you put in the first post:
620888d1568253681-ex3200-cl300-loader-converting-ssqa-img_1520-jpg
The adapter will connect up just fine with the SSQA plate on the bucket. You will have to cut off the pin mounts on the bucket and weld the 'female' SSQA plate on it.
KUHN GA4121GM 11' ROTARY HAY RAKE (A64277)
KUHN GA4121GM 11'...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
