Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #142
Hi, I'm wondering how much discount on pick ups? I live in Chatham Co. and need to visit my friend in Morganton, so you're on the way. Considering the #110 Cultivator with the bedding attachment. Thanks, Sam
/ Everything Attachments #143
Absolutely love the videos.......I get the sense that Everything attachments is committed to customer satisfaction and quality brand names.
Stay Classy
/ Everything Attachments #144
For some reason I am unable to reach "www.everythingattachments.com" from
my work computer, seems to pull up on my blackberry ok.
i get the 404 error.
the youtube site works fine,
any thoughts?
:confused:
/ Everything Attachments #147
you can go to www.isup.me
put in the website and it tests to see if it works from there... if it does then you know it is just you.....
/ Everything Attachments #148
any thoughts?
:confused:
Did you get on it yet? :confused: It's working for me.:thumbsup:
/ Everything Attachments #149
says it's "up"
click on the link and get this:
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Please try the following:
Make sure that the Web site address displayed in the address bar of your browser is spelled and formatted correctly.
If you reached this page by clicking a link, contact the Web site administrator to alert them that the link is incorrectly formatted.
Click the Back button to try another link.
HTTP Error 404 - File or directory not found.
Internet Information Services (IIS)
/ Everything Attachments #151
Is there still a shipping deal for those outside the 1000 mile area? I'm in Utah and am looking at a post hole digger, a single plow, disc, and 3point trailer hitch all for my b7300 (16hp). And any shipping help would be beneficial.
Love the videos by the way!
/ Everything Attachments #152
Everything on your list is stocked and built right here in North Carolina. We are one of the largest shippers in our zone, and that gets us a large discount on shipping to anywhere, give Ted a call at 1-866-581-5818 and you will be pleasantly surprised by our shipping rates.
/ Everything Attachments #153
Any comment on the following remarks from "old fool" dated 08-13-2011? I have contacted you about shipping costs on a rake but I have since come across this which gave me some reason for concern:
I just bought a rake from Everythingattachments.com. No problem ordering it. The price included shipping to a freight forwarder about 30 minutes away. It came on a pallet. The forwarder loaded it in the back of my one ton. At home had no trouble getting it out of PU with my BX25, a chain and the front loader. Only assembly was attaching wheels. Some of their welding mistakes made that harder than it should have been but I got it together. Then I tried to use it. Still donʼt know it it was me, the rake, or the 3 point but every time the rake would get little load of roots and junk, the tines would dig deeper. The deeper they went the more junk they collected. The more they collected the deeper they went etc., etc., etc. When I raised the 3 point a little the whole thing would spring up and drop most of the load. That is one problem. The other is the design of the wheels. If you look at a picture of a yellow York rake you will see that the vertical shaft that the wheel turns on, comes down almost in front of the wheel. It has no choice but to caster. The vertical shaft on the Everything rake comes down almost on top of the wheel. The axil is only a couple inches behind the vertical shaft. You try to make a turn, the wheel stays turned when you straighten out and then plows a nice half moon furrow down each side of the rake as you move forward. I sent an email asking if there was something I was doing wrong. I got an email saying that they got my email. Then nothing. I donʼt know if their policy is youʼve got the problem but weʼve got your money or if they knew there was a problem but didnʼt know how to fix it. Iʼm having a triangle welded to each side of the wheel bracket and mounting the axil an additional six inches behind the vertical shaft. I expect that problem will be fixed. Still donʼt know about the other one. Maybe I just need more practice. To dig up the roots I mounted my box blade leaning way forward, (hydraulic top link would have helped) extended the scarifiers, and drove around trolling for roots and rocks. Didnʼt get any trophies but did get a few keepers. One rock was about 200 lbs so I kept it in the bucket for added front traction. Who ever said it, you are right. It seems that most people just use their rake to spread gravel on the driveway.
/ Everything Attachments #154
For the gentleman that was having trouble using the landscape rake on the Kubota BX25, usually there are two problems, one is most dealers do not explain how to use a rear three point hitch that is not a position controlled hydraulic three point. On a BX, and other subcompact tractors, it has a neutral lift. That is where you leave the handle in neutral and then have an up or down. There is nothing in between. That is where knowing how to use this lift is very important. The first thing you need to know with a neutral lift is after hooking up the implement of your choice, raise the lift all the way to the top, close off the valve which is normally located between your legs,(looks like a water spigot handle.) then lower the lift. Your arms will not move because you have closed it off. Then slowly open the valve until you get the rate of fall that you like. For almost all attachments, you will operate this lift in the neutral position, and then bump the handle up or down and back to neutral depending upon what you are trying to do. But if you leave your lift in the lower position, it will continue to go down further and further, causing the exact problem the gentleman had described. We have had no problems with the wheels not tracking properly, on a smaller tractor like this, with gauge wheels and a neutral lift, what may also help in using it like a grader and not going too deep, you might try unhooking the top link and using it like a grader. I hope this helps.
Thanks for reading.
/ Everything Attachments #156
Everything on your list is stocked and built right here in North Carolina. We are one of the largest shippers in our zone, and that gets us a large discount on shipping to anywhere, give Ted a call at 1-866-581-5818 and you will be pleasantly surprised by our shipping rates.[/QUOTE
Sorry, but I'm confused by your response to dkizerian's question about the free shipping outside of 1,000 miles. Is the answer YES or NO? Love the vids, too, by the way!
/ Everything Attachments #158
The answer is no, but they get you a good deal on shipping outside the 1000mi limit.
I just ordered and received their ETA landscape rake with gauge wheels
For very reasonable $80 extra it was shipped to the Yellow Freight terminal in Denver which is 527mi beyond the 1000mi limit
I hauled it to our place in the mountains because the extra 150mi from the Denver terminal to our place at 8600' was really $pendy...
/ Everything Attachments #159
My place is 967 miles from their door, but they list the 1,000 limit about 100 miles south of here making the shipping zone 867 instead of 1,000 miles. I called them on it and they said sorry. we go by our circle and not real mileage.
Why would anyone advertise free shipping and then change the parameters by 15% less? With the easy access to online mapping that is very, very accurate, I don't see much excuse.
When I sent them a note about the issue they left a message for me asking what they could do to not lose my business. When I do order something I will probably get it from my local dealer since I always try to support the local guy, but I if the local guy does not have it in stock I may give these folks a shot, depending on his mileage limit.
/ Everything Attachments #160
kootch I am a little further north than you and last year when inquiring myself I was told for a small additional fee they would deliver it at a terminl. If I remember correctly it was in Westbrook. The additional fee ceratinly was reasonable.
Status
Swict 8' Fork Extensions (A64912)
Swict 8' Fork...
2004 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2004 FORD F150...
JOHN DEERR 850K LGP (A67714)
JOHN DEERR 850K...
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
TWO CHAINSAWS (A67714)
3268 (A63117)
3268 (A63117)
