Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #1,181
My grapple fittings leaked a little when I first used my WR Long grapple. They just needed a little tightening so nothing unusual there.
My grapple fitting leak every freaking time I use it: I have to loosen one fitting - every time - so I can get one of them to connect. It's the same one every time and it's on the tractor side. I need to find a workaround. I *think* a small clamp on the joystick controller button might work with the key on (valve is actuated), but I haven't tried it yet.
/ Everything Attachments #1,182
Close grapple, turn tractor key off to kill engine than turn key back on so 3rd function has power. If using the Kubota 3rd function make sure power button is on and cycle both joystick buttons to relieve pressure then turn tractor key back off. That should allow disconnection and re-connection without loosening anything.
/ Everything Attachments #1,183
Doesn't work.
/ Everything Attachments #1,184
Doesn't work.
Is this a true 3rd function or a diverter ? If it’s a diverter then you will need to cycle the joystick with the engine off and holding the button. If it’s a 3rd function then with the engine off and cycling the solenoid valve will relieve the pressure as said above.
/ Everything Attachments #1,185
Travis,
I've sent an email as well, could you please check on my order. I'm seriously considering a Grapple, but unsure if I can wait three weeks more. Whats the current lead time for a Wicked Grapple and Valve Kit for my CT450HST w/9TL Loader?
Thanks,
/ Everything Attachments #1,186
Travis,
Thanks,
My best estimate for Wicked Grapple lead time is 3 weeks. It's been better and shouldn't be worse. Valve kits generally ship within a week. We are experiencing business like never before, but we are also shipping more products faster than ever before. Time to up the game!
Travis
/ Everything Attachments #1,187
Travis,
Thank you for your efforts. Just had word that my current order is on the way!! Whoo Hoo.
Now, about that grapple.
I must admit I am torn between heavier duty and lighter weight. I am leaning towards lighter weight and perhaps instead of going at 72" stick down in the 55-60 range.
Anyone out there with a Grapple on a Bobcat CT450? Similar? Words of wisdom? Thoughts on "a" or "the" third function kit for the Bobcat?
Thanks all, and especially the folks at EA for their efforts. Already making use of the QD and should be digging with the teeth in a couple days.
Max
Travis
/ Everything Attachments #1,188
Do y'all carry or do you know where I can order different sized buckets for the ansung backhoe?
The backhoe that Branson is that same model you sell just with added paint and a subframe.
I have the 16" bucket but I'm looking for an 8" and a 24".
/ Everything Attachments #1,189
We have limited info on this subject. Ansung still makes things for Branson, so they're really reluctant to give info concerning what will/will not work with a Branson backhoe. Same story with Mahindra.
If you call here and ask for Jeremy, he can try to help you. Just tell him I sent you from TBN. 828-464-1200.
Travis
/ Everything Attachments #1,190
Travis,
Max
Here's the 3rd function kit. We've sold tons of them for Bobcat tractors!
Take $50 off if you buy with the grapple.
Concerning the grapple.... Man, I have choices. I'll list them, in no particular order. First is the new, exciting Wicked 60. 😍 It's an absolute 400 pound brute. I personally JUST added it to the website today. I wrote part of the description while on the phone, so take it easy on me!! Check it out here on the website.
Travis
Now, for the traditional Wicked Grapples, I've been answering this question for years and my answer is pretty much the same every time... For maneuverability I like the 60 or 54?
There痴 little weight difference between all of them, so it really boils down to what you like.
We definitely have a lot of them out there on tractors like yours.
Single vs dual lid has about as much to do with personal preference as it does functionality. The single lid pics submitted by customers are impressive to say the least, but there are some situations where dual gets my vote. Dual lids clamp extremely awkward loads more efficiently and will grab loose material like firewood better.
Single lid Wicked Grapple for Compact Tractors
Dual Lid Wicked Grapple for Compact Tractors
I know it's coming, so i'll elaborate on the two different styles. Root rake or long bottom. Both styles have certain advantages.
The dozer-like tine geometry of the rake style promotes a tractor's ability to push the tines through the ground with ease.
The root rake style allows you to pull brush, vines and other debris backwards, which isn't recommended with many long bottom grapples. Besides pulling backwards, you can also pull down. Reach up and snap a limb off the tree if you feel like it.
The root rake style will easier "unload", so you can hover over the trailer, dumpster, pile, etc., open it up and whatever you've captured is gone!
Because of the unique tine design, you will also be able to push our unobstructed long-bottom Wicked Grapple tines through the ground.
You should be able to grab a larger pile of brush with the traditional Wicked style because you can cradle and physically fit more inside it's "mouth". You can cradle things(logs, boulders, etc) with the flat bottom and stack items on it for transport. Heck, someone used it as a saw table recently. Our superior Wicked tine design is a step above any other long bottom grapple on the market!
There's TONS of Wicked Reading in the Epic Wicked Root & Debris Grapple TBN Thread.
/ Everything Attachments #1,191
Way too many choices Travis. Which style is more popular? If cleaning out a woods which one works better? It would probably be best if I stayed off this site :)
/ Everything Attachments #1,193
Just got an E/A 8' extreme duty V3.0 landscape rake a few weeks ago and got to use it a bunch today. Great quality, heavy duty and about 100 times better than my old TSC rake.
Highly recommend it to anyone looking for a HD rake!
/ Everything Attachments #1,194
Travis,
Thanks for all the info! I've made it through about half the Wicked Thread, and of course that makes me want a Grapple all the more. :D
I must say I am liking that new grapple you've got there. Though I really wish it had one thing - where is that nice Laser Cut WICKED plaque? I know it might not "do" anything, well lets say it does work to stiffen the area its attached to, but it does looked WICKED cool. Especially if someone were to paint the inside of the cutout red or such. :D
btw - One quick grapple question, have you, or Ted, or anyone, considered adding a 90deg rotation to the/a Grapple? Mechanical or Hydraulic?
In further news my shipment arrived yesterday. As luck would have it the forks were first, BUT as further luck, my Bobtach was jammed shut. Had to drag stuff off the truck loader. I've since persuaded the Bobtach to work properly and will attach a couple photos later of my new treasures.
The Wicked Grapple is still on the plate, as is a reverse rotation tiller, and either a 2 or three bottom plow.
Thanks again for all your help.
Max
/ Everything Attachments #1,195
I ordered a severe extreme with offset two weeks ago, hoping it ships in another week or so, but looking forward to getting it. I haven’t seen one in person but from what I have seen of one it should be far superior to the ones I’ve looked at locally.
/ Everything Attachments #1,196
I know how we all love pictures........
As promised here are my newest 'treasures', hot off the truck. As I mentioned, my Bobtach decided to stick (that's a photo of my Bobtach/loader with the grease gun and Kroil and PB Blaster (ran out of kroil), oh and a small persuader.) :p
I've since 'adjusted' the Bobtach and used the forks to park my new goodies in the interim Attachment shed.
More later....
IMG_20180316_173514702.jpgIMG_20180316_173556059.jpgIMG_20180316_173610610.jpgIMG_20180316_173644724.jpgIMG_20180316_173654866.jpgIMG_20180316_173721519.jpg
/ Everything Attachments #1,197
Does anyone know the paint code/type/color for the yellow E/A uses? My rake had a few good scratches from shipping (not there fault, looked like it got smacked with the fork lift, gusting at the terminal judging form what I noticed while there) and I would like to touch it up just to help prevent rusting.
/ Everything Attachments #1,198
Why not call EA?
/ Everything Attachments #1,199
More later....
View attachment 545355View attachment 545356
I had to do a double take on that backwards bucket.. :scratchchin:
On your quick connect it looks like the left lever was sacrificed along the way somewhere?
/ Everything Attachments #1,200
I believe it is caterpillar yellow not positive but it's close to it.
Status
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
New/Unused Electric 3-Wheeler (A65583)
New/Unused...
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
2006 Ford Freestyle (A64557)
2006 Ford...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
