Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #61
Hi Ted,
What Box blade do you suggest for my Deere 4320 (48 Engine HP)?
Depends;
Never mind the engine HP, what does it WEIGH ?, what tires are on it ? are they loaded ?
and, what do you plan to DO with a box blade ?, i.e. move soil (clay, sand, loam, etc) or gravel ?
/ Everything Attachments #62
Depends;
Hi,
the weight of the 4320 is 4,652 with everything included. I would be grading a gravel driveway and moving Northeastern soil with it.
/ Everything Attachments #63
Hi,
Good grief; I just looked up the specs.
I had NO IDEA it was only 3700 lbs as an open tractor.
{and I though K_word tractors were "lightweight" (-: }
I would guess another 1400/1500 lbs for a loader with bucket and maybe 1200 if you had loaded R4s on it - just guesses.
So I'm guessing you have the cab with unloaded R1 tires and no loader.
Anyway, for what you say you will be doing you could probably pull an 8ft box blade without any problem, though you would cover your tracks with a 6ft.
If you want to allow "rolling contours" side to side in landscaping work the narrower one would work better for that.
BTW, I'm in the North East (USA) and we call it "ROCKS", not "soil" (-:
/ Everything Attachments #64
Hi Ted,
I would recommend the United HD 672, you could also use the United HD 784 if you were using it mostly for leveling roads and not as much dirt moving. We just lowered our prices on all United box blades, and they are both made very well.
I just talked to them and they told me that the next load I get . . . the prices are going up, so get one out of this load to save some bucks!
/ Everything Attachments #65
Ted,
I was looking at your site and noticed that your 'Construction Attachments 42" Compact Pallet Forks' are on back order. Any idea when these may be back in stock?
Today is July 23rd so we are still around two weeks out before the new compact pallet forks get back in stock. We are substituting the Bradco Compact Pallet forks, but they weigh 280 instead of 220. They will take away 60 pounds from your lifting compacity if you are putting them on a real light weight tractor you might want to wait, but if they are going on a larger compact (the Construction Attachments are rated for tractors up to 50 hp) then you would be fine going with the Bradco to get them quick. Here is a link to the tractor pallet forks page.
/ Everything Attachments #66
Unloaded R4's with a 400X loader (weights 1045) so totally about 4,745lbs. You are right the soil is rocks :)
/ Everything Attachments #67
Thanks Ted, I will be down your way next month, so i might stop by and pick one up. Do you sell out fast? By the way love the videos:thumbsup:
/ Everything Attachments #68
Ted,
Your videos are very helpful and informative. Wish I had seen the videos before purchased my rear scrape blade. I also wish more business were as good at informing the customer. The only negative thing is, for my wallet that is, after watching your videos I have a long list of attachments I want to purchase. :)
/ Everything Attachments #69
Howdy, Ted. I have a Kubota Grand L3130 with LA723 loader, HD round-back bucket, and filled R4 tires. Total weight should be something around 5800-5900 pounds, but I am not sure about the weight of the tires. The dealer said 1200# filled, but I have not seen a figure that high on TBN. Outside tread to outside tread measures 72 inches.
We recently had about 13 acres newly cleared/stumped; quite a few pockets of trees have been left here and there. I want to disc this area for planting cover crops or mixed grasses. On other parts of the property, I will want to disc a number of food plots over time.
This is southern NH. We do not lack for rocks.
We also will have a 2800-ft gravel drive to maintain.
I am looking for recommendations on
1) Disc harrow
2) landscape rake
3) box blade
I see that your disc harrows have different blade diameters. What are the considerations for 16 vs. 18 vs. 20?
BTW, the email contact address on your website must have some issues, as two emails in the last month have gone unanswered.
thanks, bws
/ Everything Attachments #70
We just posted a New Demo Video up on our YouTube Channel. This one features a Tractor 3pt Hitch Land Leveler, and I was pretty impressed with the results after about 5 passes.
Check out the video if you haven't ever used one of these. Would work great on a LONG gravel road.:thumbsup:
/ Everything Attachments #71
1) Disc harrow
2) landscape rake
3) box blade
thanks, bws
Ok, your weight by my calculations is about 5400 hundred pounds, and this is no biggy, Here are my recommendations factoring in your intended use and conditions.
Disc Harrow - LB-B245-16-18
7ft Landscaping Rake - so you can angle and still cover full tractor width
6ft HD Box Blade
Where EXACTLY did you try to email from, the contact us form? Let me know and I will beat my internet guy over the head with it and get it fixed asap.
/ Everything Attachments #72
Nice video!! O' crap I want a land leveler now!
/ Everything Attachments #73
I really couldn't believe how easy it was to use. Peanut said that he only had to lift it twice to let out some of that Rip Rap that was under there:) and to turn around. . . . and on a long road, that isn't very many times.
Once we had it adjusted so that both blades were working, it was a set it and forget it tool instead of one that will wear you out lifting like a box blade would for something like leveling a long gravel road.
/ Everything Attachments #74
In the video, you mention taking the crown out and making it level. A well made road has a crown in the middle so that water does not collect, but rather run to the edges. It is a nice unit and I would get one if I had a long driveway to maintain, but I would create a crown and make sure I had drainage.
Thanks for sponsoring.. (I am near Spokane, WA and by the time I add shipping, I can not justify it. Have you considered a west coast distribution center?)
/ Everything Attachments #75
... Here are my recommendations factoring in your intended use and conditions.
Thanks, Ted. That's what I needed.
I used your contact us form several weeks ago and apparently y'all never got the message. Tried again, umm, last week, I think, same thing. Just thought you might want to check it out, in case something is dropping the mail.
bws
/ Everything Attachments #76
I ordered the L7200 JR PHD for my B3200 around 11 am yesterday from Everything Attachments and it is being delivered today, that is great action. Although I am in NW S.C. that's still fast delivery.
/ Everything Attachments #77
I'm not a road maintenance expert but my father was a superintended for over 30 years for a large public works in Maine. He agreed normally it's best to keep a minor crown in the road to help it drain water if there is enough material, gravel, in the road bed. Land leveler should still work just drag it so it pulls the loose gravel along the blades to the center of the road. The other thing he point out to me is puddling in a gravel road is caused by poor drainage. Even roads with a correct crown and ditching can get puddles if heavy traffic compresses the gravel base and causes an uneven surface. If water start to puddle this will cause more fines to settle in the bottom of the puddles refer restricting water drainage through the gravel. Just filling the puddle holes will not fix the problem. To fix the problem areas the gravel needs to be loosen up or dug up and refilled. Using just the ripping shanks on a box blade should do the trick then use the land leveler to finish the surface. Hopefully I relayed the information correctly.
/ Everything Attachments #78
Ted,
Will the wheel weights you sell fit on a Kioti DK40SE with industrial tires? Thanks
/ Everything Attachments #79
We try our best to stock the items so that they can be shipped out the same day if you order before 2pm. This way you are not waiting any longer than you have too.:thumbsup:
/ Everything Attachments #80
bws
My Internet guy is working on creating a new Contact Form for the site that will work the way it is supposed to. Thanks for the heads up, no telling what we have been missing by this thing only working sometimes.
Status
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
JOHN DEERE 5090 EL TRACTOR (A65057)
JOHN DEERE 5090 EL...
Cadman Powerpak PT Power Unit (A64912)
Cadman Powerpak PT...
(6) 235/80R16 Tires (A64912)
(6) 235/80R16...
Generator (A64553)
Generator (A64553)
porta potty (A68842)
