Rear Blade Everything Attachments Land leveler Review
   / Everything Attachments Land leveler Review #31
eubie5 : Not necessarily . Several of those before and after pictures are exactly like what my driveway would look like before and after , running my homebuilt land plane , several passes up and down it . We use a blue , crushed 3/4" shale , from a pit just down the road . Driveway is 800+ feet long . First 50 - 60 % is flat , with just a couple of feet elevation change . Last 40+ % starts out mild then increases to a 14% grade at top . My home built is 7' wide , by app. 8'+ long .
Really the only issue We have with Our drive , is every 4 to 6 years , We have usually 2 loads brought in to " Cap " the driveway , more to keep the dust down than anything . This past summer , Driver did good . But 5 years ago , the contract driver had No set chains on his tail gate , Thus when he was spreading and hit the steepest part of the grade , Poof . Instead of a maybe 2" cap , I had 6" to 8" thick blob for 75 to 100' . Been working the last 4 years dragging that excess either down the hill or up depending on were I wanted it . To move rock , I drop my front blade down 1" below the bottom of the side skids . To just " Touch up " the driveway , I have both the front and back blades set right at skid level . When in touch up mode , Our driveway will start out like the pictures with the grass growing down the middle . After 2 passes up and down , it will look like the after pictures .
Fred H.
   / Everything Attachments Land leveler Review #32
Agree with OP
Been taking care of about 2 miles of dirt/gravel road in woods for 30 years. Borrowed a neighbors land plane one day and ordered my own the next day. Been using it very happily for about 10 years. This thing is idiot proof. Just drop and go. You will soon be able to figure out best top link length and just usually leave it there. Mine is a 6" land pride. Many look the same so are probably pretty similar. Only issue is my skids wear out quickly and are expensive to replace. I hit the wear areas with Hard Face weld (suggested by my welding buddy) and have not needed to replace since.
I see everything attachments has a 10 degree edge on cutters instead of 5 degree. I do not know exactly whet effect that would have but would like to try.
   / Everything Attachments Land leveler Review #33
Why do towns with gravel roads run a grader over them yearly? It seems to smooth out the pot holes.
It's faster than any other method. And they have to do it yearly because it isn't the best method.....just the fastest.
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
78'' SKID STEER BUCKET (A56857)
78'' SKID STEER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
