Everything Attachments Customer Service
/ Everything Attachments Customer Service #1
Wisconsin
Kubota L4240
Hi all,
Back in October I ordered a 7 foot "Landscape Rake 2.0" from Everything Attachments. My first use was to prepare a section of a field that had been used to grow soybeans so that I could plant grass. I needed to remove the soybean debris and move a little dirt around to smooth the area. The new "v2.0" Everything Attachments Landscape Rake looked to be the most heavy duty Landscape Rake I could find.
I use my three point implements with a Speeco Quick Hitch. For me the Quick Hitch is much easier to use than shoving the three point arms around trying to line them up to a particular implement. I was pleased to see the Everything Attachments Landscape Rake was "Quick hitch & I-match compatible".
It seems most Landscape Rakes from any manufacturer imply that they can be used forward or backward in that they usually say something like "8 Forward and 8 Reverse settings". I think the reverse settings are nice for light smoothing tasks and this is a desirable feature. What many of the manufacturers of Landscape Rakes don't mention is how you're supposed to swing the rake through 180 degrees to utilize the reverse settings.
I was disappointed to find that the 7 foot Everything Attachments Landscape Rake and the Speeco Quick Hitch interfered with each other such that the rake couldn't be adjusted to the reverse settings without removing it from the tractor, picking it up from the rake's lifting ring with a chain to the loader, adjusting the rake, setting it back down and hooking it back up to the three point. I should mention that it *can* be adjusted through 180 degrees to the reverse settings without removing it from the tractor if you're *not* using a Quick Hitch. It's tight but it works.
I contacted Everything Attachments to ask about this problem. After a little back and forth Everything Attachments agreed that it was not possible to adjust the rake to the reverse settings without removing it from the tractor and they offered to take it back. I told them that I had researched this pretty throughly before purchase and, while I thought it should be able to work this way, I wasn't certain that any manufacturer's 7 foot landscape rake could do this. I told them I'd keep it but if they redesigned the rake to correct this I'd like the opportunity to receive the new part.
In my research I found that some less expensive landscape rakes have such a short piece extending from the three point hitch towards the rear that the rake contacts the rear tires before it even gets close to the hitch. Several other manufacturer's rakes would have the same interference problem with a Quick Hitch that Everything Attachments' rake had. I don't know of any manufacturer's 7 foot rake that can be adjusted through 180 degrees without removing it from the tractor but I'm sure someone here will correct me.
Anyway, fast forward to a couple weeks ago and I receive a mail from Everything Attachments telling me they've redesigned the part and would I like to receive it? I put it together today and it works perfectly.
There are four pictures/movies included below:
- Before with interference from the outside
- Before with interference from the inside
- After without interference from the outside
- A movie
As you can see they changed the design of the swinging part of the rake from an "S" to a "U" shape allowing it to clear the Quick Hitch. I'm very satisfied with their initial offer to take the rake back and their follow up offering the revised part after they changed the design.
I know this sounds a little contrived after the box blade thread but it's my experience.
Dan
/ Everything Attachments Customer Service #2
nice write up.
/ Everything Attachments Customer Service #3
So many times you hear, It look gooded on paper.
I'm glad an improved version came out for you.
I would have had buyers remorse.
/ Everything Attachments Customer Service #4
Nice, thanks for sharing.
Great work EA.:thumbsup:
/ Everything Attachments Customer Service #6
I have the same problem with my rear/back blade. It's annoying that I can't turn it around but I live with it. Nice that they offered the redsign part. That's great. Nice to hear good outcomes sometimes. Mine was not from EA. Happy new years.
/ Everything Attachments Customer Service #7
nothing like a happy ending to start off the new year...
I'm about to buy my first rear blade, with Tnt already installed on the Kubota,
and knowing what to be careful of, like clearance and range of motion, is a big help.
Good going EA.
/ Everything Attachments Customer Service #8
Yes like others have stated,nice write up,pics fore/after, video.
Boone
/ Everything Attachments Customer Service #10
Kudos for Everything Attachments, and good write up.
However one can order the off set back blade and shift it out of the way for the 180 swing.
/ Everything Attachments Customer Service #11
good to see someone create a thread on a positive experience... most only take the time to report on something if it upset them. This is why while reading reviews, I don't only look at the "percentage of positive reviews".
/ Everything Attachments Customer Service #12
Redesigning this piece of equipment is an example of tremendous customer support. You gotta love a company that takes customer support this seriously.
/ Everything Attachments Customer Service #13
I just drive backwards for the reverse setting. Seriously though, I don't use a quick hitch but my BushHog 7' rake will just barely swing all the way around but you have to adjust the 3pt to find the right spot where it will clear. With the Pat's extension it clears no problem. What I don't like about my brand though is it takes the two bolt hole tines which seem harder to find.
P.S. Good customer service though. A good advertising gimmick too. Smart thinking redesigning it.
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
2017 FORD E-350 SUPER DUTY BOX TRUCK (A60430)
2017 FORD E-350...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2016 Chevrolet...
UNUSED 1RGC40 HIGH END MINI GOLF CART (A60432)
UNUSED 1RGC40 HIGH...
