Ever get your tractor stuck?
/ Ever get your tractor stuck? #21
Kubmech is describing a variation of what is known as a "deadman". It is used when there is nothing else to anchor to. If you want easy, go look elsewhere. If you want solid, this is the answer. Go forward to solid ground, dig a trench at 90 degrees to the pull angle. secure a cable or chain to the middle of a solid log or pipe or? Bury it in the trench (works best if one end of the cable remains topside....) Place another solid log on top of trench, lay cable over top of log so cable forms a 90 degree angle when tension applied. This will hold well if dug deep using solid post or log and cable or chain is securely attached. Be very, very cautious using cable, if it breaks or comes loose under a load, it will recoil like a rubber band to the point it is still attached to. It can and will sever anything inside the arc it can describe. Humans most likely will die. Never use a frayed cable. Throw it away. Never allow a cable to slip through your hands, with or without gloves. Never stand or step over a slack cable or chain that is hooked to something, Walk around it. Work smart, not sorry.
/ Ever get your tractor stuck? #23
treeboone,
VERY, VERY well stated. As we say around here: "Safety doesn't happen by accident".
/ Ever get your tractor stuck? #24
I thought of using the chained board method mentioned by Rch and Harv when I got stuck the first time. In fact, I came back in the house, logged on to TBN, and reread the thread that described it.
There is no chance it would have worked with my tractor in the situations I was in. First, there no place on the wheel to run a chain through. Second, even if you could jury rig the board onto the wheels somehow, it cant travel very far. It will go under the wheel, yes, but then hit the 3ph. Maybe if you only have to go forward 6" to safety this would work. Third, using separate small boards, you face the same attachment problem, and, if you solve that, the boards cant rotate past the fenders on my tractor. So, maybe, you can move 12". But the small boards I do not believe would have provided enough purchase in the goop I was in anyway; planks and tires I put in front of the tires just submerged, too.
I suppose its worth a try, but maybe it can work better on a large agricultural tractor with larger clearances.
/ Ever get your tractor stuck? #25
Hey, you're right, Glenn!
Until you mentioned it, I never noticed that there are different types of wheel rims out there. Some are solid, and others (like mine) are sort of made of pieces, with plenty of gaps to run chains and/or cables through. I looked through some pictures and brochures, and they seem to show solid wheels with turf tires, and the gap kind with R1's and R4's. Too small a sample to know if there's a standard correspondence. Bet somebody out there knows.
Clearance seems to vary quite a bit, too, according to makes, models, tires and how the wheels are set. I seem to have plenty of room on my L2500, so maybe I would be prudent to put together some blocks with cables or chains, and have them already for next winter.
Or would that fall under the category of pessimism? /w3tcompact/icons/crazy.gif
/ Ever get your tractor stuck? #26
Harv,
I think all the B series Kubota's have solid rims. My JD and NH catalogs suggest that maybe the large frame versions of those tractors have gaps in the rims. The clearance problem I have is on the inside of the tire. Same thing people were complaining about in the snow chain threads--unable to fit even a chain through that gap on the 2910. If you've got better clearance, good, but query how big a board can you really get on the wheel. I wouldnt take any risks relying on this procedure.
You'll know when its risky. The little white angel is sitting on one shoulder, whining: "No, no, no, it looks goopy and risky." On the other shoulder sits the black angel, logically arguing; "You've got big tires, you've got big cleats on your big tires, you've got 4wd, you've got diff lock, don't be a wimp, go for it, see what happens, you can back out in time."
Blackie convinced me, not once but twice.
/ Ever get your tractor stuck? #27
I wish blackie had only convinced two times to go for it. He has gotten me a few more times than that./w3tcompact/icons/smile.gif
Gordon
/ Ever get your tractor stuck? #28
I've found that the best thing to anchor to when there are no trees around is...a boat anchor. It's not hard to find a place to mount to a tractor and it's designed, obviously, to stick in mud.
/ Ever get your tractor stuck? #29
Bird's steel posts, and the boat anchor are good ideas, but invariably when needed, they are back in the 'shop' and not available. Life goes on, and with inginuity, we find a way to over come our difficulties. Each situation will usually call for a slightly different solution due to the current parameters that we are faced with. Look around! Use what is available! Be open minded and adaptable, we usually can find something to do the trick.
I know I've been lucky so far in worming my way out of tough situations with my vehicles, and some of the methods hav been unorthadox to say the least.
/ Ever get your tractor stuck? #30
Harv, Glenn and Gordon,
That Black angel on you shoulder is a bad dude to over come my White angel. /w3tcompact/icons/smile.gif
There is a spot I have been working to clear for the last 4-6 Saturdays. The area had a bunch of little and big pine trees that the hurricanes knocked down over the last few years. The land falls from the south to the north and from the east to the west. This particular area is in the north west corner of what will be a pasture so alot of water moves into/through this wet spot. The area also flatens a bit so the water has more of a chance to collect, sit and soak. The downed trees formed a series of dams to keep the water from moving and of course the stump holes added to the mess. Last weekend I had cut up enough of the trees so I could finally get into the area to move the stuff that was on the ground and forming a dam. I was able to break through the downed stuff but it was a really mess in the mud. I cleared out enough of the trees that I could in theory drive the tractor through stuff that was undrivable the week before.
The problem was the mud. The more I worked in the area the worse it got. I got a good bit of the timber moved but not stacked on a burn pile and had to give up. The ruts were getting a good 6 inches deep so I figured I would get out while the getting was good. This last weekend the area had drained and dried up a good bit so I went into to put stuff on the burn piles. One area that was full of ruts last weekend I smashed into a degree of levelness just by working the area to get the timber on the burn pile. I thought I was doing good until I went up the slope a bit to where it gets a bit flatter. The tractor was to moving forward like it should be, I had been looking on the right side of the tractor so I looked to the left and noticed the left front wheel was digging a rut that had put 6 inches of mud on top of the axle. At this point my White angel said, "Dan, its time to leave, let the area dry out some more and do it again next Saturday." If my Black angel said anything I sure did not hear him! /w3tcompact/icons/smile.gif
One of my neighbors drove up a few hours later on a 1955 Ferguson 30, I think it was a 30, he just restored. He has a couple of other tractors and is retired. At least I know someone with equipment that might be able to get me out if I get into trouble! I don't think I could get my truck into the areas I might get stuck in and I don't think the truck has the traction anyway. I pretty much ignore Mr. Black Angel as a result! /w3tcompact/icons/smile.gif
My hats off to you Tractor Stuckers. /w3tcompact/icons/smile.gif I'm to chicken to play in your mud bogs! /w3tcompact/icons/smile.gif
Later...
Dan
/ Ever get your tractor stuck? #31
Just a little Pic .
/ Ever get your tractor stuck? #32
Curling the bucket and using the back-hoe is the only way to get the machine out of just about any mucky situation and the back-hoe works great getting you in and out of most tight situations
/ Ever get your tractor stuck? #33
Thats ok if you have a bucket and back hoe.
/ Ever get your tractor stuck? #34
Use a bag of masonry cement. Do not use mortar mix. Masonry cement is the stuff bricklayers mix with sand and water to make mortar. Mortar mix is sand and masonry cement. Sand does not do well to get a tractor out of mud. The lime in masonry cement will dry up the ground in the immediate area and allow your tractor some traction. You may have to lift the wheels up a bit depending on how bad you are stuck, but I have never gotten myself stuck too bad. The main thing to remember when you are stuck is to STOP trying to drive yourself out.
/ Ever get your tractor stuck? #36
One day while working in a very wet field in Texas, when I was about 13 (I'm 40 now), I got my uncles tractor stuck. Next, I got my uncles old three on the tree shift pickup stuck while trying to pull the tractor free from the mud. I wasn't looking forward to what my uncle was going to think when he got home. Anyway, some Spanish speaking only amigos walked from the local pub towards my location in the muddy field. The men laughed briskly and then started speaking rapidly and point furiously. My Spanish was poor and I wasn’t sure what they were up to. The men had me out in 20 minutes with the tools that were right in front of me all along. I’m sure they were laughing because I was young and green and they remembered learning this lesson themselves as young men. I had been trying to free the tractor for about 90 minutes. See my crude attachment for an explanation of how they managed to get me out in less 20 minutes. Mark, this really doesn't answer your question because you say "with no help". However, I thought I would pass it along anyway. I have used this same process for the last 27 years with my tractors. It works and once you collect the necessary items, keep them in the barn for later use. If you have a tractor, YOU WILL use these items again in the future. See attachment!
/ Ever get your tractor stuck? #37
Apex, what keeps the fulcrum from sinking? Seems like this would work best only if there were solid ground right next to the tractor wheel. If you had to place the fulcrum far away, you would lose all the leverage.
/ Ever get your tractor stuck? #38
Looks like the thing to have!!!!!!
/ Ever get your tractor stuck? #39
I'm not sure what you would do. I got stuck just last weekend. My Chevy K3500 barely made it budge. Thank goodness my neighbor in the back has a tractor and could come to my rescue.
Check out my stuck Kubota (there are more pictures you can see from that site as well)
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ Ever get your tractor stuck? #40
I'm impressed by a couple of things in the picture. I take it the tractor is 2WD. That does not look like alot of mud to me. I have had my JD 4700 in mud/clay up and over the front axle and up to the bottom of the rim on the back tires. I sure did not do it on purpose. I was not having to much trouble moving but when I saw what I had driven into I put the tractor into 4WD just to make sure I got out ASAP. Maybe without 4WD I would have been stuck... /w3tcompact/icons/frown.gif Impressively little mud...... Scary....
Thanks for the picture...
Dan McCarty
