Evaporation rate
/ Evaporation rate #1
bcarwell
Austin, Texas
Kabota 7500DT
Anyone know what a general ballpark evaporation rate is for a pond in Texas (presumably as a function of temperature). In other words in the 90-100 degree range, is it X gallons per square foot per hour, and at 80-90 degree range, Y gallons/sq.ft./hr, etc. ?
I realize this is a function of many other variables- wind, humidity, etc., but what are some <general> ranges ?
Farmer Bob
/ Evaporation rate #2
Farmer Bob,
Search TBN for a similar discussion. Someone just asked this with in the last month or two. Sorry but I don't remember where this was discussed nor the answer but the topic did just bubble up.
Later,
Dan
/ Evaporation rate #3
I remember the conclusion was - based on a scientific research - the evaporation depends mainly on the direct sun hitting the water.
Do a search, it is somewhere around here.
/ Evaporation rate #4
Generally you should be looking at between 1/2" and 1" a day during hot dry days in the Texas sun.
One unscientific but fairly accurate and easy way to test would be to put a water tight bucket next to the pond and see how much it evaporates.
One other factor is how much plant life there is in the pond. Plants can use a lot of water.
ALLMAND NIGHT-LITE PRO II (A68842)
ALLMAND NIGHT-LITE...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A69167)
2020 FREIGHTLINER...
225/70R19.5 Tires - Set of 2 (A68134)
225/70R19.5 Tires...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
