Evaporation rate
/ Evaporation rate #1
bcarwell
Austin, Texas
Kabota 7500DT
Anyone know what a general ballpark evaporation rate is for a pond in Texas (presumably as a function of temperature). In other words in the 90-100 degree range, is it X gallons per square foot per hour, and at 80-90 degree range, Y gallons/sq.ft./hr, etc. ?
I realize this is a function of many other variables- wind, humidity, etc., but what are some <general> ranges ?
Farmer Bob
/ Evaporation rate #2
Farmer Bob,
Search TBN for a similar discussion. Someone just asked this with in the last month or two. Sorry but I don't remember where this was discussed nor the answer but the topic did just bubble up.
Later,
Dan
/ Evaporation rate #3
I remember the conclusion was - based on a scientific research - the evaporation depends mainly on the direct sun hitting the water.
Do a search, it is somewhere around here.
/ Evaporation rate #4
Generally you should be looking at between 1/2" and 1" a day during hot dry days in the Texas sun.
One unscientific but fairly accurate and easy way to test would be to put a water tight bucket next to the pond and see how much it evaporates.
One other factor is how much plant life there is in the pond. Plants can use a lot of water.
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
2006 Chevrolet 2500HD (A64911)
2006 Chevrolet...
CAT IT28B Cab (A68134)
CAT 953C 4-in-1 Bucket (A68134)
CAT 953C 4-in-1...
(2) Galaxy 12.4-24 Tires & Rims (A64911)
(2) Galaxy 12.4-24...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
