Estimate the Weight of this log
   / Estimate the Weight of this log #11
I can see this competition is heating up, I revise my estimate to:
(((9" x 9") x pi) x 348") / 1728) x 62 lbs or exactly 2.7e+2st stone
   / Estimate the Weight of this log #13
Unlike electric motors, logs lose a lot of weight when you let the smoke out.
...though they seem to lose equal percentages in value, lol
   / Estimate the Weight of this log #14
2168# dry, or 3027# wet.
Thanks for all the replies. I also used the Woodweb calculator. I was curious to see what you guys came up with. Yes I did lift it with the tractor. I may have been able to lift a little more. With grapple weighing around 450lb, the SSQA on the loader @ 100lb, and the log at 3625 I was lifting 4175lbs.
Don't try this at home:laughing:
   / Estimate the Weight of this log #18
The ol' Kubby looks a might light in the loafers at the rear end, and a tad heavy at the front.:eek:
I wouldn't want to load the front axle up like that very often.:dollarsign:
   / Estimate the Weight of this log #19
My l5460 sure is alot more stable with weight up front when I have my #1100 BB on the rear. Easy to lift a rear wheel off the ground otherwise if too agressive while turning, esp on lumpy ground.
Excellent. Now I know what mine is capable of.
The loader on these tractors is pretty strong.
I don't think my l5460 could lift that.
Did you ever check to see were your relief is set?
This was pretty much a one time deal. I wanted to see what it would do.
I need a better ballast especially for use with the grapple. I want a compact but heavy ballast. I have a pretty cool idea for a ballast but I found the stuff to make it but IDK if the place will sell it to me. I may end up making a concrete ballast.
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
2015 FREIGHTLINER M2 26FT BOX TRUCK (A58017)
2015 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
40' CONTAINER (A52706)
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
