Error message and oil pressure indicator
   / Error message and oil pressure indicator #1
slaken
new durham, nh
MF 4608
Have a MF4608 with 64 hours on it. Today the engine pressure light when on along with the SPN (suspect parameter number) 100 and the failure mode indicator (FMI) of 18. Any clue what may be happening and what these may mean?
Thanks for the help.
Steve
   / Error message and oil pressure indicator #2
Was your tractor at idle when it came on?
No. I was doing loader work. It came on and off a number of times in a few minutes. I parked it and then went back 10 minutes later and the warning light and the number codes were gone.
   / Error message and oil pressure indicator #4
How old is your machine?
Got it in July 2013. Only 68.3 hours.
   / Error message and oil pressure indicator #6
There is an update for the oil pump drive gear retaining bolts. The bolts will break and the drive gear can slip causing a low pressure situation. What dealer did you get it from? They should know about it. There was an notice a month or so ago. Supposedly no harm as it's a very quick no pressure when the idle speed slows and the bolts fall into a cavity in the timing cover. But if the bolts are broken the timing cover has to come off to fish them out.
New Boston Truck and Equipment in New Hampshire. Thanks. Can I still use it? I'll contact the dealer and ask about the recall and the fix tomorrow morning. Appreciate the help. I always assume I must have done something wrong...
   / Error message and oil pressure indicator #8
Though it should be fine, I would limit use. It's a lot easier to not cause damage in the first place than have some thing get messed up and have more repairs. Let them make the call on that one. Of course it's a great time of year when no ones busy.
   / Error message and oil pressure indicator #9
Do you know your serial number?
Yes on the s/n. Good in use as I am clearing land and get by with it in low gear with no loads. I'll ask the dealer to confirm.
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
BESTWAY AG VSK50 LOT IDENTIFIER 26 (A53084)
BESTWAY AG VSK50...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
LMC LOT IDENTIFIER 238 (A53084)
LMC LOT IDENTIFIER...
