erratic idle
/ erratic idle #1
hounddawg2
2006 branson 3510
My branson 3510 jumps from 400rpm to 1300rpm in idle. If I throttle up too around 2300rpm does ok unless in a bind. Already cleaned tank and lift pump replaced feul filter any suggestions
/ erratic idle #2
Did you pull out the air filter and run it to see if that makes any difference? I take it that is a diesel? Then check for loose fuel injector nuts. In tank pick up maybe clogged up.
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
2006 Volvo Semi (A64047)
2006 Volvo Semi...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
YARD MULE (INOPERABLE) (A63569)
YARD MULE...
2021 CHEVROLET EXPRESS S/A UTLITY BODY (A59910)
2021 CHEVROLET...
