erratic idle
/ erratic idle #1
hounddawg2
2006 branson 3510
My branson 3510 jumps from 400rpm to 1300rpm in idle. If I throttle up too around 2300rpm does ok unless in a bind. Already cleaned tank and lift pump replaced feul filter any suggestions
/ erratic idle #2
Did you pull out the air filter and run it to see if that makes any difference? I take it that is a diesel? Then check for loose fuel injector nuts. In tank pick up maybe clogged up.
Bobcat MT85 (A60462)
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
Lot 1001 (A64047)
Lot 1001 (A64047)
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
STARCRAFT BUMPER...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
