Rockbadchild
Super Member
With a clay soil it would be harder to remove rocks in a undisturbed soil, for any implements to dig in and for your tractor to pull that implements.I’m in central Kentucky and have clay soil.
I have the same tractor and a one bottom plow and a disc so we are going to find out, if it ever stops rainingYanmar SA 425 is an 1,850 pound, under 25-horsepower tractor.
Not enough tractor weight, not enough power to pull a Disk Harrow of effective weight.
I suggest a Middlebuster, AKA Potato Plow, with replaceable plow blades. Ample for a one (1) acre food plot. Relatively cheap, low draft resistance (low traction requirement), short operator learning curve.
Tarter produces 'CountyLine' brand implements as private labels for Tractor Supply Company.
MORE ON YOUTUBE:
I guess maybe I should specify a little more on these rocks. I’m not talking softball sized rocks, I’m talking 2 plus footers. We have huge chunks of limestone in the ground where I’m at
Last summer I was in my neighbor's yard doing a small job with my tiller and noticed he had a rock that he had been mowing around.one guy I worked with wanted to expand his field and there was what look like couple feet diameter rocks but it didn’t matter what you throw at them they didn’t want to budge, so after trying a few things without result he rented a excavator to dig these rocks. Turn out these rock where huge 20” long megalithic like rocks… like iceberg only the tip was sticking out, only then he understood why the old timer left that area alone…
| Lift Capacity (Pivot Pin) lb. (kg) | 1,200 (545) |
Your LOCATION will allow your respondents to match implement recommendations to availability in your area.
My father had a rock like that which he was tired of mowing around, so he started working at it with his 1010 JD crawler. He got it out of the ground but that's as far as he could get it. So they planted flowers around it, and that's where it's been for 30 years or more.Last summer I was in my neighbor's yard doing a small job with my tiller and noticed he had a rock that he had been mowing around.
It was about a foot in diameter and stuck out of the ground about 6 in. I asked him if he wanted me to pop that out of the ground while I was there with my tractor. He said you can if you want but I've put this spud bar on it and I can't budge it or get it out of the ground. Should have been my first red flag but... "Oh cool a challenge."
Long story short, an hour and a half later I started out with my small SCUT and we got the rock and it's brother, almost as big, exposed but we could not lift them out of the ground. With the help of a spud bar shovel and tractor. They were probably 700+ pounds. One was about two and a half feet across and the other one was at least two feet.
So I went up the road and got the big tractor and popped them out.
It was actually kind of fun for me I don't know about him.
If you ever run out I have plenty that I can donate.When I cleared a small plot intending to put in a small orchard, I had a similar situation. Lots of rocks, some 2-3 footers. I used my box blade with the shanks down to “pull them to the surface”. Then used my front end loader bucket, rolling them in, moving them, and creating a huge rock pile that my neighbors and I utilize when we need rocks.
Jack
you are talking about me right ? yes I met 20 feet my bad and good catch... thanks I'll edit itIm assuming you meant 20 feet.. I have numerous 20” rocks and those are not too bad to dig out.. biggest rocks ive found on my property are maybe 36” in one direction but usually smaller in the other. Not 36” spheres, is what i mean. Anyway, judging by the fact that my tiny loader struggled with the biggest one and knowing the loader lift at various heights, the heaviest one ive found was around 1100lbs.
