Equalizing forward/reverse speed on CK2610H?
/ Equalizing forward/reverse speed on CK2610H? #1
dieselfuelonly
Chapel Hill, North Carolina
Yanmar YM1401D
Is there any way to adjust the reverse travel speed on a CK2610H? It drives me absolutely nuts that reverse is so much slower than forward, especially when doing a lot of loader work with direction changes. For one it makes the linked pedal near useless because the engine only reaches about 2/3 of the RPM in reverse as it can in forward. There seems to be less pedal travel overall for reverse. In order to match the speed of medium range forward travel, I have to shift to high range in reverse. Any ideas??
/ Equalizing forward/reverse speed on CK2610H? #2
I don稚 think that it will ever be equal, I believe reverse is just a lower gear, maybe I知 wrong.
/ Equalizing forward/reverse speed on CK2610H? #3
With mine when I'm doing a lot of back & forth using the linked pedal I just advance the hand throttle to about 18-1900 and it helps the reverse movement go quicker.
3pt 4' Rhino SE4 (A64127)
3pt 4' Rhino SE4...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
LMC 3pt 6' Box Blade (A64126)
LMC 3pt 6' Box...
2021 Caterpillar 306 CR (A64126)
2021 Caterpillar...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
