equalizer for cab install
/ equalizer for cab install #1
escavader
Veteran Member
western maine
bx-23 ,
Thought id share.Imade this device to help install/remove my homemade cab.The cab has loops on the corners for lifting on and off.Icut two lengths of thick wall tubing,slightly wider than the cab[to avoid scratching the paint] welded 8 inchs of chain on each.I connected the two and reenforced with some thin flat plate.Welded a loop in the middle for the chain fall to hook to .WELL HOPE YOU CAN SEE IT WITH THESE PICS:D Iused rope to remove what a pain that was.This kept things lifting even
ALAN
Unused Hustler Standard Style Loader Kit (A66734)
Unused Hustler...
2012 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A66736)
2012 Freightliner...
PORTA POTTY (A68842)
2015 John Deere CX15 (A64126)
2015 John Deere...
Case SV300 High Flow Compact Wheel Loader Skid Steer (A66734)
Case SV300 High...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
