Engineering Question - Bolt Grade and Material
/ Engineering Question - Bolt Grade and Material #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
I am building a scrape blade.
I need a bolt for the blade to pivot on to set the angle.
The bolt I need is 1 inch diameter and 8 inches long.
What material and grade of bolt should I use.
See attached picture to see which bolt.
Thanks.
Pooh Bear
/ Engineering Question - Bolt Grade and Material #2
I wouldn't use a bolt. Bolts are not designed for shear loads and if you torque the bolt properly to put it in compression instead of shear you'll curse every time you need to change the angle.
I'd use a hardened pin with hardened washers top, center and bottom.
Wouldn't a grade 8 bolt be about the same as a hardened pin?
I won't be changing the angle very often.
I don't mind messing with bolts to do this.
Pooh Bear
/ Engineering Question - Bolt Grade and Material #4
A hardened pin I think is a bit more stout. I don't think it is quite grade 40, some might be.
Might look for something like a spindle, can handle the shear load and use a castle nut. That would allow the required ability to angle the blade, provide shear protection.
Check out boltcouncil.org. or a hardware guru. A 1" grade 8 might be able to withstand a shear load required for the blade. Might have ask some smarter than me.
/ Engineering Question - Bolt Grade and Material #5
My blade is similar to yours and uses a 1" grade 8 bolt, washer top and bottom, and a lock nut snugged up just enough to take up the slop. Bear in mind that my blade is about 30 years old and has had a lot of "work" done to it. However, the bolt has worked well so far. The blade is 72" wide and I have loaded it to the limits of 4WD traction without any problems.
/ Engineering Question - Bolt Grade and Material #6
I used a single 1" grade 8 bolt for my pivot and 2 7/8" pins to lock it into place. After 3 years and plenty of abuse I have had no problems.
/ Engineering Question - Bolt Grade and Material #7
Mornin Pooh Bear,
You might consider a shoulder bolt rather than a standard bolt !
/ Engineering Question - Bolt Grade and Material #8
Bolts can take all kinds of loads: compression, pulling, shear, bending.
Lower grade bolts can take more deformation before they crack.
When you guys mention grade 8 bolts, is it the same as 8.8 quality bolts they sell in Europe ? 8.8 are able to take 800 N/mm2 (which is 80 kg per square mm of diameter surface)
All 8.8 bolts are electrolyticaly zinc coated.
You cannot buy thermically zinc coated 8.8 bolts because the heat of the zinc bath changes the characteristics of the metal back to the level of the original material before the strength treatment. Same is with welding, if you heat up the material of an 8.8 bolt, reckon its equal to 4.6 bolts, which handle about 600 N/mm2
For making anchors to be poured into the concrete to mount metal structures on, usually 4.6 is taken, because 8.8 will crack in 80% of the cases when you bend a threaded rod into an L shaped concrete anchor. 8.8 is stronger but stiffer and will crack sooner at a lower level of deformation.
OOh, and for the practical side of the story: it might be handy to weld a solid rod on either the bolt or the nut, so you can adjust the angle without having a wrench with you on the job.
Most scraper blades i've seen have a toothed ring that holds the blade at angle, so you can adjust it in steps of 15 degrees or something. You can make your own by welding some L shaped bars on the scraper top plate, and two strips of metal (wedge shaped like a portion of apple pie) on the A frame, to lock up inbetweent the L bars.
Well, I guess a grade 8 bolt it is then.
I won't be doing much adjusting "in the field".
I'll never be more than 600 feet from the shed at any time.
If I need to adjust it I'll just go get a wrench.
This thing won't see a lot of use or abuse.
The hitch structure is built like a tank.
Only weak points are that pivot bolt, and the 4 bolts that
will hold the blade to the pivoting mounting plate.
My tractor is a 1949 8N.
I don't think there is enough HP there to do any damage to the blade.
Mostly gonna spread loose dirt, mulch, and gravel.
My house and property.
http://web.infoave.net/~poohbear2767/panorama.htm
Thanks.
Pooh Bear
/ Engineering Question - Bolt Grade and Material #10
Try to put the solid part of the bolt in the shear area instead of the thread part. This makes the shear strenth alot higher and it won't ware out in the pivet as fast. Don't use all thread which is soft.
/ Engineering Question - Bolt Grade and Material #11
Renze, 8.8 is approx equivalent to Gr5. Gr8 is about like 10.9. Good points about heat and bending. Up to 400F can be used without changing the metals basic characteristics however. This is a great tool to enable bending of stiff metal with less danger of cracking. To gauge the temp clean the metal down to a shine and heat until natural silver color changes to straw brown. Bend it. If you accidently go past straw to blue its a little oops. If it glows red you have truly compromised the heat treatment badly. Also, threaded rod presents a worst case situation for stress in bending due concentration of stress in the notches. Threads on the inside and outside of the planned bend should be ground off.
Larry
/ Engineering Question - Bolt Grade and Material #12
You're right, what they call "carf working" at the technical engineering schools in Holland, applies to threaded rods, which means that, on the inside of a thread, more strain occurs than if it was in a similar rod, straight, with the same diameter as the diameter of the threaded rod minus the thread depth.
tractor pulling folks usually have their rough crankshafts ground smooth to make them stronger... It sounds stupid, grinding material away to make it stronger, but it's true...
Well, I was out and about today and stopped at Tractor Supply.
I picked up a hitch pin and a couple of lower link pins.
The one inch diameter hitch pin and a washer seems to work great.
Hope that little pin at the bottom holds up.
Still used a bolt to hold the angle adjustment.
Have to go get a wrench to change the angle.
Doubt I will be doing that very often anyway.
Thanks.
Pooh Bear
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
KJ K3325 33'x25' Barn Shed (A60463)
KJ K3325 33'x25'...
Prime 452 (A60462)
Prime 452 (A60462)
2019 Case IH True-Tandem 335VT (A60462)
2019 Case IH...
500BBL SKIDDED FRAC TANK (A60736)
500BBL SKIDDED...
