Engineered lumber span chart
/ Engineered lumber span chart #1
ejb
Platinum Member
Can someone with a litle more building/engineering experience help me with a question regarding engineered lumber?
I am designing my addition/remodel, and one of the spaces that we end up with in order to get the look that we want is a second story space with a width of 33 feet from one outside wall to the other.
I am going to put a 12 pitch roof over the whole thing and am trying to figure out if there is engineered lumber that I can use as roof rafter that would allow me to not having any interior load bearing walls.
I found this document on the Georgia=Pacific website <A target="_blank" HREF=http://www.gp.com/englumber/pdf/10-11.pdf>http://www.gp.com/englumber/pdf/10-11.pdf</A> that seems to map it out but not sure what all the live/dead numbers mean.
Anyone interpret this for me??
Thanks.
PS: I live in a SNOW area so I think the second page od the PDF is the document I need.
EJB
/ Engineered lumber span chart #2
What the chart says, is that your out of luck! Yes, you'd need the second page. At the lightest snow load, 25psf, with 15 psf dead load, the largest one they make is just short of 33'. You would have to check your local building codes to determine the design loads. The live load, would count a snow load, and the dead load is the weight of the joist, sheeting and roofing. 15 psf is pretty standard for joist, sheeting, asphalt shingles. I can't remember typical snow loads, but it varies depending on where you are.
I would try a local lumber yard, they should be able to help you out. They will know the design loads, have the tables and may have access to different manufactures products to help you out.
Another thing thing to consider is trusses or truss joists, there are many different engineered products out there right now to choose from.
Maybe I wasn't clear, (or maybe I was and I am still out of luck) the fllor span is 33 feet, but the rafters would need to be about 24-25 feet from peek to the end.
(As a side note, anyone remember how to figure out the length of a isiclese triangle if you know the angle and the length of the third side??)
It looks to me like lumber is available to cover 25 feet, just not sure what the live and dead loads refer to...
/ Engineered lumber span chart #4
When I built my house, there was a setion in the back, with a recessed lania, and I wanted regular roofing over it, not the vinyl or aluminum.
It was a bit tricky between code, and design, but I ended up using wood ibeams to help with the span. Trussing was a bit expensive though.
Soundguy
/ Engineered lumber span chart #5
You need to talk to an engineer or architect who is qualified to design your building. He will know the required dead and live load values for your area (wind, snow, etc.). What you want to do can probably be done, but I suspect you will wind up using engineered trusses rather than simple rafters.
/ Engineered lumber span chart #6
On a 12/12 pitch you would need a rafter length 23.33 feet long. You would also need to add the length of any overhangs to that length. The formula is X squared + Y squared = Z squared.
33 feet divided by 2 = 16.5 feet. X 12 = 198 inches. 198 inches squared = 39204 + 39204 = 78408. The square root of 78408 = 280.01428 inches divided by 12 = 23.334523 Feet. I am not sure what yor snow loads are, but this is not a unreasonable span in my opinion. The timber thickness would have to be sized for your intended use.
/ Engineered lumber span chart #7
<font color=blue>how to figure out the length of a isiclese triangle </font color=blue>
An isosceles triangle has 2 equal sides, but not necessarily a 90 degree angle included.
The formula is (a squared) = (b squared + c squared) if you are talking about a right angle triangle (45x45x90). If not, then it is much more complicated. You will probably need a set of trig formulas for that one. My book shows multiple formulas depending on the knowns and unknowns.
/ Engineered lumber span chart #8
ejb,
If the angle you know is either of the equal base angles, then the length of either of the equal sides is: L= (base/2)/ Cos angle
If the angle you know is the angle between the equal sides the the length of the side is: L = (Base/2)/(Sin angle/2)
Al
/ Engineered lumber span chart #9
A bit off topic here, but I read many of the subs here on TBN, and have noticed something about the users here. It would seem that of the available user population, we seem to have a higher percentage of engineers than other occupations. Anyone else notice this?
Soundguy
crb478 and others:
Thanks for the formula...I suppose I could have tracked it down somewhere on the internet but this makes it easy.
The 23ft span does seem reasonable. Will setup an appointment with the engineer at the lumberyard to figure out what kind of engineered lumber I need for my loads and spans so I can frame in the new second story...my guess is it won't be cheap (the engineered lumber that is). Good thing I work for free/w3tcompact/icons/smile.gif
Thanks all/w3tcompact/icons/smile.gif
/ Engineered lumber span chart #11
I think the formula your looking for here is the Pythagorean Theorem which states: the square of the length of the hypotenuse of a right triangle equals the sum of the squares of the lengths of the other two sides. As has been simply stated A squared + B squared = C squared
Why not go with a scissor truss (for a vaulted look) or an attic truss (if storage is what your after)?
/ Engineered lumber span chart #12
Chris,
Probably true, but how many really get to drive the train??/w3tcompact/icons/wink.gif
Al
Thanks for the link...trusses would do the span, but I am interested in putting the space to use so they are out. A good (and probably cheaper) solution if I didn't need to use the space...thanks.
/ Engineered lumber span chart #15
You can get a room truss that has the walls built in. They are not cheap, but go up quickly so labor is usually less. This only counts if you are hiring it out. They are also stronger. and usually take up no more room than a framed in knee wall would. Think of it like a triangle with a rectancle inside of it. The bottom cord is used as your floor joist and the top as rafters. I highly recommend them, and the joist company engineers the loads and gives a warrantee with them as long as they are installed correctly
Check the prices with different companies, sometimes the prices vary greatly. Some times you can get lucky and they are the cheapest alternative to use.
/ Engineered lumber span chart #16
What your describing is an attic truss. They usually come with a 2 x 8 or 2 x 10 bottom cord. I've installed them on garages for people. They tell the local inspector the area is for storage. As soon as they get the final, walls go up and carpeting goes down. Go figure, who'd want to use a carpeted area for storage.
/ Engineered lumber span chart #17
Around here they refer to them as room trusses and they are intended to be habitable rooms. The bottom cord will vary in size up to around a 2x12 depending on how the live loads engineer. They are used about 50% of the time and usually spaced on 16 or 24 inch centers. Once they go up the room is framed in as well as the rafters put in place. Attic trusses many times do not have the necessary head room or live load strength to be considered habitable.
/ Engineered lumber span chart #18
Must be a regional definition. The no headroom ones we refer to as storage trusses. We're talking the same animal, but with a different name.
/ Engineered lumber span chart #19
yep, ours have 8 foot headroom and up. some have tray ceilings built in. No wonder your inspectors look hard at the ones you see.
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
159120 (A60430)
159120 (A60430)
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
