engine won't fire, clueless
/ engine won't fire, clueless #1
Citydude
Super Member
Northeast Wyoming
Kubota L4060 HSTC
Today, I was in the process of wiring in work lights on the front and rear of the canopy on my L3400. Somewhere along the process, I discovered that the engine won't fire. It turns over great. I checked all the fuses however noticed that before, when I turned the key on there was a distinct "click" and the glow plug indicator was on. Now, no glow plug indicator light comes on and no click. I also noticed that the seat safety switch doesn't click when moved up and down. Would the seat switch cause this? Stumped....
/ engine won't fire, clueless #2
I had the same problem with my bx it happened a couple of different times. Check to make sure that you didnt bump the pto lever and all so the seat switch move it up and down a few times by hand.
I checked the PTO lever and moved the seat switch up and down. Is the seat switch supposed to make a clicking sound? I thought I remembered it did, now it doesn't.
found the issue! I put the fuse in the wrong slot. Sometimes I wonder how I lived this long being such an airhead.....Thanks!
/ engine won't fire, clueless #5
Sounds like you put the fuse in the wrong slot, to me.:p
/ engine won't fire, clueless #6
Yep, has all the symptoms :yes:
You guys are good! Now where is my tractor? It was here yesterday.....
/ engine won't fire, clueless #8
LOL, I think square1 did it.
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
