Engine trying to shut down.
/ Engine trying to shut down. #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Engine seems like it is starving for fuel when going down hill even with full tank. Replaced fuel and air filters, no help?
Any ideas?
/ Engine trying to shut down. #2
Check the pressure on the lift pump.
Forgot to mention the tractor is a kubota bx2230
/ Engine trying to shut down. #5
Is the lift pump the fuel pump?
Disconnect the fuel line at the lift pump (it's the pump ahead of the injector pump in most fuel systems). Crank the engine like you are starting it and you should see a CONTINUOS gush of fuel from the fuel line. If it dribbles or is intermittent work your way back to the tank and find the restriction. The usual culprits are a blocked or pinched fuel line, a plugged filter head, or a clogged tank outlet. Some lift pumps have a screen on the inlet side that can clog.
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
Chevrolet Silverado Service Truck (A64194)
Chevrolet...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
JOHN DEERE GRAIN DRILL ROW MARKERS (A64280)
JOHN DEERE GRAIN...
213083 (A64276)
213083 (A64276)
