Engine stalls
/ Engine stalls #1
R Madison
Hello - I'm new to the site and I'm also a new owner of a '78 S650G.
The tractor starts, idles and runs perfect at higher RPM/s. The problem is getting it up to speed - it's hard to get it to take gas off idle. The only way to increase the RPM from idle is to SLOWLY give it throttle. Too much throttle too fast will stall the engine every time. After finessing the throttle to get the RPM/s up it runs perfect. Any Ideas?
Thanks!!
/ Engine stalls
Turnsout the points were just barely opening. Adjusted the points to .025 and it eliminated the stalling.
Any idea what the correct gap for the point is supposed to be???
Thanks,
Ron
/ Engine stalls #3
No , not really but about 15 would be better , 25 will give to much dwell angle . Check they are not pitted which makes setting with a feeler gauge impossible . If it uses a distributor put a couple of drops of oil on the felt pad in the shaft to lube it . Also a LIGHT smear of Petroleum Jelly on the cam lobes to stop the point rubbing block wearing out .
/ Engine stalls
Perfect. Thank you very much!!!
-Ron
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
159119 (A60430)
159119 (A60430)
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
